Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > VygisToolbox
Old 02-06-2007, 13:44   #1 (permalink)
oldcoyoteinc's Avatar
Member: 204211
Thanks Meter: 41
KG225 imei repair
i cant write imei to kg225 with vygistoolbox v1.66, v1.68, v1.70, v1.71 v1.72. try with all versions
Old 02-06-2007, 14:33   #2 (permalink)
Member: 4458
Thanks Meter: 25,853
And how you tried to write it?
Regards,Vygis
Old 02-06-2007, 15:08   #3 (permalink)
Member: 204211
Thanks Meter: 41
the phone was powered on without simcard. i press read info and operation fails. i press factory reset and operation fails, i press read imei and operation fails. then press ctrl+I click on change imei, i wrote imei then click write imei button and again operation fails. Please help me
Old 02-06-2007, 15:13   #4 (permalink)
Member: 4458
If you can't fix IMEI from "Special" section-try to fix it with "Repair IMEI" function from "Unlocker" section-and other,check if your cable pinout is correct,it must be same as is shown in "Pinout info.txt" (cable for C1100,...)
Regards,Vygis
Old 02-06-2007, 15:18   #5 (permalink)
Member: 4458
One more thing - reset phone with 2945#*# and try one more time from "Special" section-if this won't help,and also cable pinout is correct-fix IMEI from "Unlocker" section.
Regards,Vygis
Old 02-06-2007, 16:53   #6 (permalink)
Member: 204211
Thanks Meter: 41
Regards,Vygis
all right man, i will try this method and post results as soon as possible
kg225 imei problem! doublex_gsm FuriousGold 5 04-14-2008 15:11
SonyEricsson W800 - Unlock/IMEI Change/IMEI Repair - Which Cable? gaz_0001 Sony Ericsson 3 08-26-2006 17:00
Samsung E720 - Unlock/IMEI Repair/IMEI change - which cable?? gaz_0001 Trident/AGERE Platform 2 06-22-2006 18:13
804ss/z540 The IMEI repair.Bluetooth repair liufeifei QUALCOMM Models (3G) 1 05-17-2006 16:10
P2K Ultimate Box, Unlocking, IMEI Repair, Chinese flash repair and more! VictorGSM Main Sales Section 0 07-31-2002 04:36
Page generated in 0.15368 seconds with 9 queries
