can't flash nokia 3100 after update n-box to v2.6 1 Attachment(s) before the update it was ok but now when i clik flash a pop up apear like the posted picture, and when i clik ok, this is the result 1st Boot Ok, DCT4, UPP: 1120 Fl0: 0x01000000-0x00FFFFFF,00000001, Algorithm: Unknown 2nd Boot Error: Error Data1: 00000000: 9B 01 02 01 00 00 00 01 00 00 00 00 02 00 00 00 ................ 00000010: 01 00 00 00 00 00 00 00 01 00 02 00 03 00 04 00 ................ 00000020: 05 00 06 00 07 DB 00 00 00 00 00 00 00 00 00 00 ................ 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Error Data2: 00000000: 01 00 00 00 01 00 00 00 00 02 00 00 00 01 00 00 ................ 00000010: 00 00 00 00 00 01 00 02 00 03 00 04 00 05 00 06 ................ 00000020: 00 07 DB C3 72 00 00 00 00 00 00 00 00 00 00 00 ....r........... 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Before taking screenshot, expand this window ! Process Failed, Repowering Mobile any solution please?! |
need help please what can i do to flash 3100 without this error? |
if you just try to update sw version or change ppm then there is a problem with nbox sw if phone is dead then it's a flash chip problem as you don't have corect flash ID please tell more: phone is OK or phone is dead? br sorinm |
I Need Rh5 Flash File 4 The Ff Nokia 1100.2100&2300 Plese Help And 3650 Dead Flash File |
http://www.axnet.pl/flashe/login.php |
[QUOTE=bono_x100]before the update it was ok but now when i clik flash a pop up apear like the posted picture, and when i clik ok, this is the result 1st Boot Ok, DCT4, UPP: 1120 Fl0: 0x01000000-0x00FFFFFF,00000001, Algorithm: Unknown try to turn on the power until it flash. after fash mcu ok and extract content file ok, before flash ppm it get error again because can get power from phone. you must reflash and tick ppm only,and try turn om power until flashing. sorry for my bad english ,i hope you understand. |
try to turn on the power until it flash. after fash mcu ok and extract content file ok, before flash ppm it get error again because can get power from phone. you must reflash and tick ppm only,and try turn om power until flashing. sorry for my bad english ,i hope you understand.[/QUOTE] how can i turn on my phone, it's dead. |
when, 1st Boot Ok, DCT4, UPP: 1120 Fl0: 0x01000000-0x00FFFFFF,00000001, Algorithm: Unknown you must press the power switch again and again,until it flashing. when flashing put the charger to increase the phone power. not to power on the phone , i hope you understan. |
i will try it and see |
i think you have bad flash chip as it doesn't show corect flash ID. it's true that sometimes you have to power on manually nokia 3100/6100 look at the power led form your box. pres power on when you see it light. it blinks three times. try to sincronize with it. but i think you have bad flash chip. resolder it. |
