08-21-2007, 15:01 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Age: 37
Member: 164786 Status: Offline Thanks Meter: 56 | Problem flashing at high speeds Since I bought my box, I can't do some operations using high speed(= or > 460800, in some software I can't use more than 230400). I already tried to change PC/USB Cable. For example, the old freia for ufsx, i can't work at 460800 with Siemens A52, but I can flash at 921600 using an ordinay USB CP2101 cable. With latest SAMs, I can't unlock E2P in X658 with speed more than 230400. But I can flash Nokia DCT4 at max speed without problem. I have the same problem with the new SeDBx, for example, I can't read GDFS using the speed more than 230400. I have: UFxBoot V2.2 (c) SarasSoft 2003., UFS_USB V2.6 (c) SarasSoft 2005 I need know if there are any firmware update or other thing solves my problem. Thanks in advance. Code: Unlock E2P X658 Flash Device: Spansion S29WS128N Baud Rate Set: 460800 bps Bad Resp: 0xC0, 0x1FC4 at: 0x02FA6000 MCU Read Failed, at: 0x00026000 Flash Device: Spansion S29WS128N Baud Rate Set: 230400 bps MCU Read Done, 524288 byte(s), Time: 00:23, 0 E2P Info: SIMLOCK STATUS: 01 MCC-MNC: XX-XX #SIMLOCK*NET*XXXXXXXX# IMEI: XXXXXX-XX-XXXXXX-X E2P Saved as C:\Arquivos de programas\SarasSoft\UFS\UFS_SAMs\Read\X658_XXXXXX-XX-XXXXXX-X_E2P.bin MCU Write Done, 278528 byte(s), Time: 00:13 EDIT: I bought a new K750 and have the same problem. I can't use LG_GSM too. |
08-23-2007, 13:14 | #4 (permalink) |
Member: 164786 Status: Offline Thanks Meter: 56 | Here a screenshot of LG MG220 booting as 7050. when i select to unlock, first the soft makes a backup. In one screenshot, LG GSM gives me an error when trying to backup at 460800, but don't give when I select 115200. |
08-23-2007, 19:20 | #6 (permalink) |
Member: 164786 Status: Offline Thanks Meter: 56 | but this same phone I boot in Vygis at 812500 with no problems. KZF, for example, I can boot but I can't unlock nothing, always I get error when the reading process starts, with "high speed" checked or not. |
08-27-2007, 16:18 | #8 (permalink) |
Member: 164786 Status: Offline Thanks Meter: 56 | unlocking lg c1100 @ 460800 If used non Auto-Ignition cable, press Power-On button Boot Ok, FL_ID : 98 00 84 [TOSHIBA] 00 BaudRate Set to: 460800 IMEI: 356192-00-XXXXXX-X Read Framing Error: 7646 Unlock Failed ----------------------------- unlocking lg c1100 @ 115200 If used non Auto-Ignition cable, press Power-On button Boot Ok, FL_ID : 98 00 84 [TOSHIBA] 00 BaudRate Set to: 115200 IMEI: 356192-00-XXXXXX-X Read [01000000-01001FFF] Done, Time: 00:00 Cal. Data Saved as C1100_356192-00-XXXXXX-X_2782007_093130.bif Unlock Done, Time: 00:00 I need to unlock and flash at higher speed possible! Time is money and I know that n-Box can do it. Please, answer me... Thanks in advance. |
ks360 high speed or low speed same Problem | cityyemen | Z3X-Team Products | 0 | 12-10-2009 02:21 |
How TO FLASH LG3G HIGH SPEED !!!!!!!!! WITH REDBOXII | sunnyc | Redbox | 4 | 10-07-2005 04:51 |
USB high speed flashing | muckyboy | Remote Universalbox Team | 8 | 12-16-2004 20:32 |
Siemens high speed flashing pci card? | gsmsalers | Siemens-Benq RingTones and WallPapers | 9 | 02-18-2004 09:02 |
