Nbox error is flash ok friend I'm adding you on msn! |
Hi, anyone can help me on this Authentication stage error: Connection Closed Gracefully. |
Click Here For the Updates |
first use update ufs frimware and give him rag.fbi file after this your computer will genarate reg file of your box sireal number after this use reg to fbi cunverter cunvert your reg file to fbi repate update ufs frimware now use generated fbi file box shows box key ok now click start hwk update button your hwk will be update and 100 work without error |
error Quote:
Hwk error??? 1 Attachment(s) HWK unexpeted fixer AFTER USE THIS SOFT SHOW ERROR HOW CAN I RECOVER BOX PL. HELP |
DO NOT, perform this process unless you have Box Auth Error 20, update client reports "use Update Firmware to authorise UFS !" or you are advised to do so. 1. Run the update client. 2. Select your language. 3. Click "Next". 4. Wait until the "Update UFS Firmware" button is enabled and then click it. 5. Select req.fbi file, you will need to get this file from the support area. 6. After a few seconds the process will complete and create a file called xxxxxx.req. (where xxxxxx is your UFS serial number) 7. Send this file to your UFS reseller. 8. When you receive xxxxxx.fbi from your UFS reseller, perform steps 1-4 above. 9. Select xxxxxx.fbi 10. After a few seconds your box will be authorised. Your UFS reseller is the only person who can help with this process, do not ask here in the forum, we will not generate xxxxxx.fbi files for you. NOTES:- 1. the xxxxxx.fbi file sent by your UFS reseller is one time use only. 2. once you have made the xxxxxx.req file, do not perform any other steps on the box, since this will cause the xxxxxx.fbi file to be out of sync. |
*** share bos__i like it |
supeb work sir...keep it up |
how about BOX_AUTH_ERROR:32 how to solve this problem |
