Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Unibox
Unibox The Universal Box By Teleway
Old 10-16-2004, 08:50   #1 (permalink)
Phil's Avatar
Member: 2735
Thanks Meter: 28
USB Unibox
USB Unibox
The USB Unibox is basically a replacement for usual serial datacables, it is more flexible, cheaper and more handy than to obtain all the datacables independtly. That`s why it is a must have item for every serious unlocker or repair shop that get a lot of different phone brands and models everyday.
It`s based on a FTDI 232BM USB to RS232 converter chip and the driver sets it up as a virtual comport of your choice.
Unibox Specification:
- Based on FTDI 232BM chip
- Indication LED`s for Power, Flash Supply, RX & TX
- Uses RJ45 Plug for connecting the needed Phone cable
- You can manually switch between FBUS and MBUS
- Optional 5V test voltage for flashing some Phones like Trium and Ericsson
- It gets external supplied so it works also on Laptops and with Softwares that doesn't enable the power
- Power supply is taken from USB
- Support also for the remote unlock service
Pinout of the RJ45 jacket:
1 = Switchable 5V Flash Supply
2 = TX (output, data to phone)
3 = RX (input, data from phone)
4 = RTS (output, data to phone)
5 = CTS (input, data from phone)
6 = M/C-BUS (bi-directional 1 wire bus)
7 = GND
8 = GND
Pinout of the RJ48 jacket:
1 = DCD (input)
2 = RxD (input)
3 = TxD (output)
4 = DTR (output)
5 = GND
6 = DSR (input)
7 = RTS (output)
8 = CTS (input)
9 = RI (input)
10 = +5V
(DCD & RxD are internally connected)
Mobile phone Cables that are included 100 Pieces + 1 Nokia Adapter Cable
And fitting for the following models:
NOKIA 3510 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 3210 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 3310 (F/M-BUS) Unlocking; Change Logos and ringtones
NOKIA 5110 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 8210 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 8310 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 8910 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 7650 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 3650 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 9210 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 7210/6610 (F/M-BUS) Unlocking; Change Logos and ringtones
NOKIA 6100 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 5100 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 6800(F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 3300(F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 5510 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA N-gage (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 3200 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 3320 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 1100 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 6600 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 6650 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 7600 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 6280 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 7200 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 6230 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 5140 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 3220 (F/M-BUS) Unlocking, Change Logos and ringtones
NOKIA 6250 (F/M-BUS) Unlocking, Change Logos and ringtones
ERICSSON T28/A2618/R320/R310 Unlocking; flashing; IMEI change etc.
ERICSSON 388/338/377/318/398/337 Unlocking; flashing; IME change etc.
ERICSSON 788/768/A1018/T18/T10 Unlocking; flashing; IMEI change etc.
MOTOROLA T191 Unlocking, flashing (worked also the non-3 pins Sendo
phone)etc.
MOTOROLA T205 Unlocking, flashing (worked also the non-3 pins Sendo
phone)etc.
MOTOROLA V60/66/70 Unlocking, flashing (read info only), Internet etc.
SIEMENS
C25/S25/C35/M35/S35/SL45/S45/ME45/A35/A36 Unlocking / Connecting /
Internet / Logos and Ringtones, change IMEI etc.
SIEMENS S55 Unlocking; flashing
SIEMENS C62 Unlocking
SIEMENS C30 Unlocking
SIEMENS ST55 Unlocking; flashing
SIEMENS S40 Unlocking
ALCATEL BE, ADB: Unlocking; flashing
ALCATEL BF 310/311/510/511: Unlocking; flashing
ALCATEL BG OT525 Unlocking; flashing
ALCATEL BF OT715 Unlocking; flashing
ALCATEL BH4 OT535 Unlocking, flahsing
ALCATEL XG1 OT320 Unlocking; flashing
ALCATEL XG1 OT531 Unlocking
ALCATEL OT320 Unlocking
PANASONIC G450 Unlocking; flashing
PANASONIC GD55 Unlocking; flashing
PANASONIC G60 Unlocking
PANASONIC X70 Unlocking
PANASONIC GD90/GD70 Unlocking
PANASONIC GD92/GD93 Unlocking
PANASONIC G50 Unlocking
SONY CMD-C5/Z5/Z15/Z18 Unlocking; flashing
SONY CMD-J5/J7/J70 Unlocking; flashing
Bosch 509 Unlocking; flashing
Bosch 909/908 Unlocking; flashing
PHILIPS Savvy Unlocking
PHILIPS Fisco Unlocking; flashing
PHILIPS P530 Unlocking
Sagem 7xx/8xx Unlocking
Sagem MYC2
SAGEM 9XX/MY-5X
Unlocking;flashing; IMEI change etc.
MITSUBISHI
Trium/Astral/Geo/Galaxy Unlocking; flashing; IMEI change
MITSUBISHI Trium Mars/Neptun: Unlocking; flashing; IMEI change
MITSUBISHI M330/M320/M322I/110: Unlocking; flashing; IMEI change
SAMSUNG A300/N400/R2XX/C100 Unlocking
SAMSUNG SGH600 Unlocking
SAMSUNG SGH2200 Unlocking
SAMSUNG A100 Unlocking
SAMSUNG A200 Unlocking
SAMSUNG C100 unlocking
SAMSUNG S100 unlocking
SAMSUNG E700 unlocking
SAMSUNG A800 unlocking
SHARP GX10/GX10/GX1 Unlocking
LG600: Unlocking
LG1200: Unlocking
LG510: Unlocking
LGu8110: Unlocking
LGB1300 series: Unlocking (Vygis scheme)
LGC1100 series: Unlocking (Vygis scheme)
LG7050: Unlocking
Sendo: S200 Unlocking
Sendo: M550 Unlocking
Sendo: S300 Unlocking
Toshiba TS21i Unlocking
NEC N21 N22 N22i, N223i
NEC e606
Maxon 7922
Benq: Unlocking
XDA RS232 cable
Switch description:
BUS mode switch: Select with this if you want to use the 2 wire FBUS mode or the bi-directional 1 wire bus mode.
5V flash supply switch:
Enable or disable with this switch the 5V flash supply on pin 1 of the RJ45 jacket. When the flash supply is enabled the LED for it will light.
Operating Instructions:
Connect the box to your PC and connect the power supply to it, the Power
LED will light up as soon as you have connected it. Choose now the
operating mode and connect the phone cable and the phone.
Operating mode examples for various phones:
- Nokia Phones, enable Fbus or M/C-Bus mode - depending on your software.
- Ericsson Phones, enable Fbus mode and also the 5V flash supply to operate.
- Motorola T191 and T205 enable Fbus mode to operate.
- Motorola V60/66/70, enable Fbus mode and also the 5V flash supply to operate.
- Siemens Phones, enable Fbus mode to operate.
- Alcatel Phones, enable Fbus mode to operate.
- Panasonic Phones, enable Fbus mode to operate.
- Sony Phones, enable Fbus mode to operate. (For Z5 and CD5 it`s needed sometimes to enable flash supply!)
- Philips Phones, enable Fbus mode to operate.
- Bosch Phones, enable M/C-Bus mode to operate.
- Sagem Phones, enable Fbus mode to operate.
- Trium Phones, enable Fbus mode to operate (for flashing phone you must enable the flash supply!)
- Samsung Phones, enable FBus mode and and also the 5V flash supply to operate.
Remark:
- It`s the option for the user that have no RS232 on the PC (Laptop) anymore but still need to operate software using comports.
- Please note that some Software or phone might be incompatible by using such USB <--> RS232 converter and still require the "real" RS232 to work properly
-The RJ48 is available of all rs232 signals in 3.3 volt levels
The Following 20 Users Say Thank You to Phil For This Useful Post:
USB unibox Inovator Unibox 8 08-16-2017 20:45
Where to get drivers for NSDongle USB UniBox? FractalizeR NSPRO 6 12-05-2005 17:06
Do i Really Have to Modify my USB Unibox ?? Is it Necessory ??? Aamir_Zia VygisToolbox 2 01-02-2005 16:33
Smart-Clip, USB-Unibox, Modified Twister,....... koksi Main Sales Section 0 05-22-2004 07:41
Page generated in 0.16269 seconds with 9 queries
