USB Unibox USB Unibox http://www.tele-way.com/service/unib...%20photo_b.jpg The USB Unibox is basically a replacement for usual serial datacables, it is more flexible, cheaper and more handy than to obtain all the datacables independtly. That`s why it is a must have item for every serious unlocker or repair shop that get a lot of different phone brands and models everyday. It`s based on a FTDI 232BM USB to RS232 converter chip and the driver sets it up as a virtual comport of your choice. Unibox Specification: - Based on FTDI 232BM chip - Indication LED`s for Power, Flash Supply, RX & TX - Uses RJ45 Plug for connecting the needed Phone cable - You can manually switch between FBUS and MBUS - Optional 5V test voltage for flashing some Phones like Trium and Ericsson - It gets external supplied so it works also on Laptops and with Softwares that doesn't enable the power - Power supply is taken from USB - Support also for the remote unlock service http://www.tele-way.com/service/unib...inout-rj45.jpg Pinout of the RJ45 jacket: 1 = Switchable 5V Flash Supply 2 = TX (output, data to phone) 3 = RX (input, data from phone) 4 = RTS (output, data to phone) 5 = CTS (input, data from phone) 6 = M/C-BUS (bi-directional 1 wire bus) 7 = GND 8 = GND Pinout of the RJ48 jacket: 1 = DCD (input) 2 = RxD (input) 3 = TxD (output) 4 = DTR (output) 5 = GND 6 = DSR (input) 7 = RTS (output) 8 = CTS (input) 9 = RI (input) 10 = +5V (DCD & RxD are internally connected) Mobile phone Cables that are included 100 Pieces + 1 Nokia Adapter Cable And fitting for the following models: NOKIA 3510 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 3210 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 3310 (F/M-BUS) Unlocking; Change Logos and ringtones NOKIA 5110 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 8210 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 8310 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 8910 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 7650 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 3650 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 9210 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 7210/6610 (F/M-BUS) Unlocking; Change Logos and ringtones NOKIA 6100 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 5100 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 6800(F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 3300(F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 5510 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA N-gage (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 3200 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 3320 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 1100 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 6600 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 6650 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 7600 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 6280 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 7200 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 6230 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 5140 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 3220 (F/M-BUS) Unlocking, Change Logos and ringtones NOKIA 6250 (F/M-BUS) Unlocking, Change Logos and ringtones ERICSSON T28/A2618/R320/R310 Unlocking; flashing; IMEI change etc. ERICSSON 388/338/377/318/398/337 Unlocking; flashing; IME change etc. ERICSSON 788/768/A1018/T18/T10 Unlocking; flashing; IMEI change etc. MOTOROLA T191 Unlocking, flashing (worked also the non-3 pins Sendo phone)etc. MOTOROLA T205 Unlocking, flashing (worked also the non-3 pins Sendo phone)etc. MOTOROLA V60/66/70 Unlocking, flashing (read info only), Internet etc. SIEMENS C25/S25/C35/M35/S35/SL45/S45/ME45/A35/A36 Unlocking / Connecting / Internet / Logos and Ringtones, change IMEI etc. SIEMENS S55 Unlocking; flashing SIEMENS C62 Unlocking SIEMENS C30 Unlocking SIEMENS ST55 Unlocking; flashing SIEMENS S40 Unlocking ALCATEL BE, ADB: Unlocking; flashing ALCATEL BF 310/311/510/511: Unlocking; flashing ALCATEL BG OT525 Unlocking; flashing ALCATEL BF OT715 Unlocking; flashing ALCATEL BH4 OT535 Unlocking, flahsing ALCATEL XG1 OT320 Unlocking; flashing ALCATEL XG1 OT531 Unlocking ALCATEL OT320 Unlocking PANASONIC G450 Unlocking; flashing PANASONIC GD55 Unlocking; flashing PANASONIC G60 Unlocking PANASONIC X70 Unlocking PANASONIC GD90/GD70 Unlocking PANASONIC GD92/GD93 Unlocking PANASONIC G50 Unlocking SONY CMD-C5/Z5/Z15/Z18 Unlocking; flashing SONY CMD-J5/J7/J70 Unlocking; flashing Bosch 509 Unlocking; flashing Bosch 909/908 Unlocking; flashing PHILIPS Savvy Unlocking PHILIPS Fisco Unlocking; flashing PHILIPS P530 Unlocking Sagem 7xx/8xx Unlocking Sagem MYC2 SAGEM 9XX/MY-5X Unlocking;flashing; IMEI change etc. MITSUBISHI Trium/Astral/Geo/Galaxy Unlocking; flashing; IMEI change MITSUBISHI Trium Mars/Neptun: Unlocking; flashing; IMEI change MITSUBISHI M330/M320/M322I/110: Unlocking; flashing; IMEI change SAMSUNG A300/N400/R2XX/C100 Unlocking SAMSUNG SGH600 Unlocking SAMSUNG SGH2200 Unlocking SAMSUNG A100 Unlocking SAMSUNG A200 Unlocking SAMSUNG C100 unlocking SAMSUNG S100 unlocking SAMSUNG E700 unlocking SAMSUNG A800 unlocking SHARP GX10/GX10/GX1 Unlocking LG600: Unlocking LG1200: Unlocking LG510: Unlocking LGu8110: Unlocking LGB1300 series: Unlocking (Vygis scheme) LGC1100 series: Unlocking (Vygis scheme) LG7050: Unlocking Sendo: S200 Unlocking Sendo: M550 Unlocking Sendo: S300 Unlocking Toshiba TS21i Unlocking NEC N21 N22 N22i, N223i NEC e606 Maxon 7922 Benq: Unlocking XDA RS232 cable Switch description: BUS mode switch: Select with this if you want to use the 2 wire FBUS mode or the bi-directional 1 wire bus mode. 5V flash supply switch: Enable or disable with this switch the 5V flash supply on pin 1 of the RJ45 jacket. When the flash supply is enabled the LED for it will light. Operating Instructions: Connect the box to your PC and connect the power supply to it, the Power LED will light up as soon as you have connected it. Choose now the operating mode and connect the phone cable and the phone. Operating mode examples for various phones: - Nokia Phones, enable Fbus or M/C-Bus mode - depending on your software. - Ericsson Phones, enable Fbus mode and also the 5V flash supply to operate. - Motorola T191 and T205 enable Fbus mode to operate. - Motorola V60/66/70, enable Fbus mode and also the 5V flash supply to operate. - Siemens Phones, enable Fbus mode to operate. - Alcatel Phones, enable Fbus mode to operate. - Panasonic Phones, enable Fbus mode to operate. - Sony Phones, enable Fbus mode to operate. (For Z5 and CD5 it`s needed sometimes to enable flash supply!) - Philips Phones, enable Fbus mode to operate. - Bosch Phones, enable M/C-Bus mode to operate. - Sagem Phones, enable Fbus mode to operate. - Trium Phones, enable Fbus mode to operate (for flashing phone you must enable the flash supply!) - Samsung Phones, enable FBus mode and and also the 5V flash supply to operate. Remark: - It`s the option for the user that have no RS232 on the PC (Laptop) anymore but still need to operate software using comports. - Please note that some Software or phone might be incompatible by using such USB <--> RS232 converter and still require the "real" RS232 to work properly -The RJ48 is available of all rs232 signals in 3.3 volt levels |
