GSMSERVER GSM Shop
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 04-14-2009, 19:17   #1 (permalink)
Member: 166086
Thanks Meter: 9
A137 read codes failed
Only get failed message tried 1000 times?????
Old 04-14-2009, 19:50   #2 (permalink)
SUUNNYY's Avatar
Member: 885625
Sonork: 100.1589108
Thanks Meter: 2,432
Originally Posted by jjrock View Post
only get failed message tried 1000 times?????
hi friend check your cable,check phone connector,make sure that no other ftdi device is connected to pc,configure ns pro to a port below then 10,retry,regards,suunnyy
Old 04-14-2009, 21:02   #3 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,394
Click GET INFO then connect powered off phone with battery inside to NsPro C450 cable:
The Following User Says Thank You to Elco For This Useful Post:
Old 04-16-2009, 22:49   #4 (permalink)
Member: 285074
Thanks Meter: 20
exactly 100% tested, cable c450 ....
Old 04-17-2009, 12:57   #5 (permalink)
Member: 562205
Thanks Meter: 7
A-137 unlocked successfully
Hi mr. elco,
Thanks for update. Your tool is so easy to use. I have unlocked A 137 at&t, and it is on 850/1900 mhz. Can i convert it to 900/1800. If possible please suggest.
regards.
mg
Old 04-17-2009, 13:11   #6 (permalink)
Member: 152547
Sonork: 100.1586021
Thanks Meter: 142
nspro is doing grteat these days.please keep it up.
but check the virus on the new update ver5.10
Old 04-19-2009, 08:47   #7 (permalink)
Member: 562205
Thanks Meter: 7
change of bands of samsung a137
Hi, can we change bands of samsung a 137 to 900/1800 mhz. If possible please share.
Regards.
mg
Old 04-19-2009, 09:44   #8 (permalink)
GSM-XPERTS's Avatar
Member: 1001830
Sonork: 100.1652282
Thanks Meter: 242
there is no virus detected in my antivirus ... check ur antivirus
l6i Failed to read codes yui Smart-Clip 26 06-11-2010 10:55
How to read code A137? maciekbednarz UST Pro II 2 06-24-2009 10:13
E2100 read codes failed pls help!!! newfoundghori UST Pro II 3 06-03-2009 11:26
Blackberry 7230 read code failed nadeem_75 FuriousGold 2 03-04-2009 14:02
D820 Read code fail But Direct Unlock DONE !! TPS UST Pro II 4 11-15-2006 22:08
Page generated in 0.35098 seconds with 8 queries
