BAD Dongle BAD Elco BAD Support HELLO FIRST THING , THIS FORUM IS FOR HELPING USE FOR OUR PROBLEMS FROM ELCO , BUT WHY ELCO DON'T HELP ME ??????????????? I HAVE POST MY PROBLEM MANY TIMES BUT NO RESPONCE FROM ELCO http://forum.gsmhosting.com/vbb/showthread.php?t=270902 http://forum.gsmhosting.com/vbb/show...4&postcount=53 http://forum.gsmhosting.com/vbb/show...7&postcount=46 ALL THE OTHER BOXES AND THE FREE SOFTWARE WORK VERY GOOD WITH D500 , WHY NSDONGLE ALWAYS HAVE A PROBLEM WITH THIS PHONE |
GOOD Support, GOOD Elco, GOOD Dongle. Quote:
Rather than look to solve problem prefers to blame others. IF All you say was true then Elco's software and dongle wouldnt be the best in the market as 100s of users will tell you. |
Sometime new update have some bug, you just report to Elco he will fix it. I have some problem also but after new update problem solve. Now never problem with nsdongle for me.I never use one soft, one dongle, so I can test and compare wich one is the best. Now if possible I need Elco add function read & write EEPROM. Thanks |
Elco it's not a software problem ( firmware ) , i have do repair then flash and the same , the same firmware used with the other boxes on the same phone and it's ok . IT IS YOUR SOFTWARE PROBLEM OF NSDONGLE , please repair it |
Man are u programmer or what? Nsdongle software work perfectly for me no bugs on flashing and i know this man he work very hard on samsung |
1.Use flash with Repair mode checked. 2.After flashing, power on the phone with sim inside. 3.Power off the phone and rebuild IMEI.Rebuild IMEI. Is much better than read/write EEprom. |
If 99% if the people using nsdongle do npt have any major problems then that would suggest that any problems are not with nsdongle "perse". Perhaps you should first consider how many developers there are for the other software and OS and hardware that you are trying to us NSdongle on and with, and maybe complain to them. One thing is for sure, you dont get the level of support from Mickysoft that we get from Elco. I for one, have been more than happy and continue to be more than happy with nsdongle and with the support kindly offered by Elco and Crew (keep it up guys) sure i have had 1 or 2 minor problems, most of which have been ironed out in the next release, but that is the nature of complicated software. So Cobra02a i suggest rather than ranting, you actually look around in the forum for the answer to the problems you may have, rather than having a go at Elco and crew, that you politely ask for there help, and be grateful that you have the support. |
