Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 01-12-2006, 00:12   #1 (permalink)
geosan1638's Avatar
Member: 5204
Thanks Meter: 35
To All Users With Ns Box Problems!!!
Because of fault in the box some of you might be getting errors when flashing using NSDongle BOX.
I have made some easy explications on how to fix your box in 2 minutes:
1.Remove the rezistors marked with red( R23 and R26) in picture repair 1. Now try to flash a phone and see how it works, if all ok then you may close the box and enjoy your NSDONGLE.
VERRY IMPORTANT!!! This will void your warranty.
Hope i has of help to you
WBR
Old 01-12-2006, 00:39   #2 (permalink)
The Repair Shop's Avatar
Member: 307549
Thanks Meter: 188
but if the boxes are faulty, an't it better to send the box back to the resller?
Old 01-12-2006, 00:44   #3 (permalink)
geosan1638's Avatar
Member: 5204
Thanks Meter: 35
This is somenthing that your reseller can tell you ..this solution is for ppl that need to flash their Samsung "now" and can't wait for the round trip of the dongle.
BTW the succes of the repair by removing the 2 rezistors r23 and r26 has a sucess rate of 99,9%.
And again it is just a fix ...this is not recomended by anyone but me so take as it is.
WBR
Old 01-12-2006, 18:14   #4 (permalink)
geosan1638's Avatar
Member: 5204
Thanks Meter: 35
and sorry because i forgot; before doing repair 1 remove de cryptobox from inside.
Old 01-12-2006, 18:19   #5 (permalink)
Member: 183888
People, unless your willing to void your warranty please just contact your reseller.
Great info though, although I can't confirm if this works or not.
If this does not help you it means that the GL850 chip is defectiv(this is an USB Hub) and this gets us to point no. 2
2.Remove the GL850 chip from PCB and do this 2 connections as shown in the picture repair2. Please note that if you remove this IC the CryptoBox(small lock stuck in the usb port inside NSDongle BOX) has to be inserted in another USB port( one in your computer).
WBR
to all user and team .. attention pls THE GREAT ONE FuriousGold 7 03-30-2010 09:15
To all Users who have some problem with client tool 6.00 gsminfo SagMaster Team OLD Products 3 01-23-2007 17:41
!!!!! To all users who have problems with server today!!!!! SoftMobile MT-BOX 9 12-25-2006 14:56
to all user arabic now you use ust with lang arabic without any problem amralkareem UST Pro II 0 12-16-2006 12:47
Top sagem DD Team & to all user having problems with bootloader failed(Sticky please) djyash SAGEM JTAG UNLOCKER 1 12-02-2005 10:39
Page generated in 0.19313 seconds with 10 queries
