D880 Master İmei Change Problem (000000...) mater imei change problem oparetion log... Entering TAT Mode... MSL Security Detected! Calculating MSL... Writing IMEI... Setting Bluetooth device address... Operation successfully completed Slave İmei Change Ok master imei change problem Phone is Flashing and eeprom writing ns pro versions NsPro v4.3.1_11 and NsPro v5.0.0 beta_2 not change :confused: |
Download master eeprom file from support area write eeprom file use new algorithm and write imei B.R., Sonu Quote:
eprom problem brother i do 2 pieces its 100% eprom problem write eprom and then unlock your problem will be slove |
write eeprom file "D880 eeprom.nsf" for master after imei 000000000000000 not change imei and flashing write phone master and slave not change:( |
change with UFS, it work 100%. but nspro change too. |
only unlock |
Hi! Thank's Can you explain that, problem up to which IC (or any things?) on PCB (problem where is it)? It can be done? footnote: --------------------- Excuse me! My English is not good. |
If HW Then Post Here Your Problem https://forum.gsmhosting.com/vbb/f258/ |
Entering TAT Mode... Writing IMEI... Operation successfully completed |
