06-24-2006, 06:30 | #2 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
06-24-2006, 13:14 | #3 (permalink) | |
Freak Poster Join Date: Oct 2005
Member: 191662 Status: Offline Thanks Meter: 2 | Quote:
Today i try d600 i can not do anything, phone just starts charging?? | |
06-24-2006, 13:24 | #4 (permalink) |
Member: 191662 Status: Offline Thanks Meter: 2 | Ok managed to do D600 but still having problems with teh E900....i get an error from windows saying something about a "malfunction" Please i need a solution to this problem asap |
07-06-2006, 18:12 | #5 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 44
Member: 59489 Status: Offline Thanks Meter: 55 | Did you manage to solve your problem shahzad9? Im having the same problem with the E900, try rebuilding the IMEI and get 'operation failed', even after get info goes through fine. |
08-24-2006, 00:56 | #10 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Peh Bhooti, Pakistan Age: 42
Member: 49896 Status: Offline Thanks Meter: 14 | eclo i repaired an e900 IMEI before but im trying to do another one but it comes up as saying operation failed. I gets info and it sometimes work and when i tried to write IMEI it comes up with operation failed. What can i do?? |
08-24-2006, 01:06 | #11 (permalink) |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Use NsPro v1.2c and connect powered off phone with battery to NsPro.Operation take 2-3 seconds. PLZ check if blue led is lighting up when starting operation.If not, reinstall NsPro Box driver. Last edited by Elco; 01-17-2007 at 17:06. |
08-24-2006, 09:22 | #12 (permalink) |
Member: 49896 Status: Offline Thanks Meter: 14 | i have done that and even the blue light says on, however the phone can only get info. It wont unlock or change IMEI?? Keeps coming up as operation failed. Is there something wrong with the phone?? |
08-24-2006, 16:04 | #14 (permalink) |
Member: 49896 Status: Offline Thanks Meter: 14 | The SW version is E900XXFF2 but now i get the following error Setting Test Mode... Checking Security Type... Calculating MSL Address... Bypasing MSL security... Writing IMEI... Setting Bluetooth device address... Operation failed! |
E900 IMEI Repair!! WORKS 100% - Ns Pro 1.2 | mobilextreme | NSPRO | 9 | 01-16-2007 09:57 |
e900 imei repair | spaced69 | Trident/AGERE Platform | 1 | 11-27-2006 20:23 |
E900 - Imei repair, not working. | mobilextreme | NSPRO | 8 | 09-19-2006 13:23 |
E900 imei repair give keypad problem | cairnquay | NSPRO | 4 | 09-12-2006 14:58 |
E900 imei repair | pearsonjohnboy | NSPRO | 2 | 08-07-2006 02:28 |
