G800 unlock problem Hi i seems to have problem unlocking any Samsung G800 If i plug my E210 cable in the box i get this USB Hub power exceeded Checking serial communication... Operation failed! If i use the adaptor and plug the E210 i get this Checking serial communication... Operation failed! I know the Cable is fine as i just got it replaced and i can do J700i, G600, U900 with NO problem I have got no error on the drivers side, they are install propelly as far as iam aware A little bit of help would be apreciated :D |
Elco or anybody any solution??? |
done that many time but no response stuck on Checking serial communication... |
The phone connector is fine and clean |
@youkosa Check that phone modem drivers r installed properly then try again. |
just keep pluging cable and powering up the phone and execute unlock not last command was having same problem just sorted it out |
Not sure if this helps , but i could not get the handset to connect for over an hour , with about 50 attempts to connect. The next day I set the software to flash , changed back to unlock WITHOUT pressing change jobs , then i went back to change jobs /unlock, and it connected first time ,and unlocked very quickly . it was so quick I had doubted that it was even unlocked , but on checking, it was. In other words , KEEP TRYING! [oh , and clean the port and data cables too :D:D:D ] |
the solution is with the usb cable not with rj45 i try it and it work for me and it work perfect... |
After reading my own instructions , I found it failed on me this time! Another way to do it to fire up nspro , press unlock. It will ask to enter *#726872#, which you do. When you press ok , it cannot find the handset . NOW turn off nspro , switch off the phone , and repower nspro. You press unlock , and when asked to press the pc mode code, just press ok , then power on the phone as it is searching for the phone. Have done a number of them now , and seems to work ok! .Give it a try:D |
Count supported models - 203 Searching Samsung USB interface... not found Searching Samsung USB interface... not found ----------------------------- Model: U900G CountryCode: DTM Factory SW: U90GBOHL1 UniqueNumber: 80250000143239 MemoryPhone: K5R2G1GACM(U900) IMEI: 35524302581280/8 Phone S/N: RVIS140980 Build: M6281A-KLRZ-4.0.9530 Reading SysInfo... OK Calculating... OK Calculating codes... OK (time - 00:00:57) Freeze code: 17580406 NET lock: #7465625*638*68293603# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# ----------------------------- No answer from phone Error read info ----------------------------- Model: U900G CountryCode: DTM Factory SW: U90GBOHL1 UniqueNumber: 80250000143239 MemoryPhone: K5R2G1GACM(U900) IMEI: 35524302581280/8 Phone S/N: RVIS140980 Reading SysInfo... OK Calculating... OK Searching Samsung USB interface... not found Unlocking... OK (time - 00:00:03) good work z3x teem |
