Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2005 Age: 54
Member: 137980 Status: Offline Thanks Meter: 166 | help ?after instal 5.2.0 ,usb not reconeised |
![]() | #2 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,394 | Quote:
In this case, contact your reseller and ask him to replace your box. All nspro boxes have 6 months waranty. | |
![]() | #4 (permalink) |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,394 | oh... in that case, open the box and check the box form hardware problems. There may be a problem on box USB connector. Resolder the connector. That might solve the problem. If you replace the box, keep the original card. The activations are stored on the smartcard. Not on the box. |
The Following User Says Thank You to Elco For This Useful Post: |
![]() | #6 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,503 | help ?after instal 5.2.0 ,usb n Friend!I have two NS-Pro activate for multi.Same situation you have.Same times I have this error.I think is not problem in Reader or Card (most important) but in drivers conflit. Try remove program, all drivers and install all new again. In device Manager clean all drivers s not in use,panel control all Modens,Remove Cracks or Emulatores from computer (If Have) after this connect Box with a good USB datacable to USB Computer and not in any HUB. Try this is Software problem.But you can Remove Card from Box and put In one reader (Pkey for example) Work fine.But try this. Good Luck Haicha |
The Following User Says Thank You to Haicha For This Useful Post: |
![]() | #8 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2005 Location: TuNiSiA Age: 40
Member: 111457 Status: Offline Thanks Meter: 966 | NS Pro smart card, can't be used with pkey reader. but the problem is in smart card reader, u can use infinity, cruiser, setool, vygis, scard, or other device who support shlumberger smart card. br ![]() |
