06-23-2009, 06:41 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: On Earth
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | How can I unlock the phone code for Samsung S5233a? |
06-25-2009, 04:05 | #5 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 44
Member: 111457 Status: Offline Thanks Meter: 967 | i don't have this file right now, but maybe will work properly with S5230 flash file wich is available. i u wanna try it, try it at ur own risk. i u wanna try it, do not flash boot from the begin, just flash the rest of files and see what's happen. if u get an error while flashing rc2, maybe u need to flash first boot file but use it at ur own risk. SGT-S5230_MultiLoader_V5.56.exe S5230 S5230XEID6 S5230XEID7 S5230XEIE5 br |
The Following 3 Users Say Thank You to BouRRi_GSM For This Useful Post: |
11-22-2009, 06:02 | #10 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Hi Install Drivers select Correct Mode do as Soft says.... Connecting failed is Communication issue from Your Side... all drivers were in nspro root directory C:\Program Files\NsPro\NsPro Driver |
The Following User Says Thank You to Amir-SkillZ For This Useful Post: |
12-07-2009, 11:00 | #12 (permalink) |
Freak Poster Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 44
Member: 120908 Status: Offline Thanks Meter: 38 | thats only unlock but procesing making 30 minute for that so long but that work |
The Following User Says Thank You to jufong For This Useful Post: |
02-12-2010, 14:55 | #15 (permalink) |
Freak Poster Join Date: Jan 2009 Age: 39
Member: 951755 Status: Offline Thanks Meter: 25 | if u the right drivers installed, u can use the e210 cable when u connect the phone (powered off) to the dongle, and go for Get Info. when u'r phone powers ON switch it to a USB cable. it worked for me. |
How can I unlock the security code for htc P3400? | caremobiles | HTC & PDA WM( With Touchscreen) | 4 | 11-07-2012 09:20 |
Can Setool Reset The User Code For Samsung D880?? | vmin81 | SETool2 | 8 | 05-26-2011 09:51 |
How can i get the puk code for my kp500 | bunglebum | LG | 1 | 01-01-2009 20:30 |
How can i unlock the security code of NEC Phones????? | MUNEEB_AKHTAR_RAZA | NEC | 2 | 11-09-2005 17:02 |
how can i unlock the phone coode from sl45 please help | denis10 | x1x to x45/x50 | 1 | 08-12-2002 04:28 |
