how to reset security code of samsung I450???? how to reset security code of samsung I450???? |
check ur post in z3x u will get solution there i posted link there |
Use ns pro select i-450 press unlock after unlock sucsuss /now user code set as 00000000 |
type *2767*3855# without sim card.... if no luck you can use UST PRO or NSPRO BOX if you have procedure just unlock your phone again... |
2.2: i450_phonelock http://www.megaupload.com/?d=NN6N0U72 WAIT FOR LAST ONE REGARDS,SUUNNYY;) |
HI FRIEND HERE IS 1: Apollo ver 4.21 http://www.megaupload.com/?d=VUEUAM27 2. i450_phonelock http://www.megaupload.com/?d=NN6N0U72 3.i550_i560_phonelock_0815 http://www.megaupload.com/?d=WMXXHPUA ALL DONE FINALLY,ENJOY:) GET RID OF CODE:) ,REGARDS,SUUNNYY;) Quote:
regards !!!<<< svchost.exe >>>!!! |
friend suunyy can you help me i put phone in modem mode *+# + power button connect to pc with e210 usb cableinstall drivers but when i open the apollo soft not find phone why??? |
how to do ? Power Off the Phone, Push ' 7 - * - Power Button ' it will bring you to download mode, you need to use E210 Usb Cable (Not RJ) Install Drivers after that Run Apollo Software, Software Automatic Find modem Port, Select Your Req. file and click Download after finish wait 5 minut and Enter "00000000" NOTE-----Select Your Req. file ---------IN YOUR CASE REQUIRED FILE IS I450_PHONELOCK.BIN ALL THE BEST FRIEND:),WITH BEST REGARDS,SUUNNYY;) |
tell us if it does not work i will upload another file for u. |
