01-30-2009, 22:08 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: the earth Age: 41
Member: 103024 Status: Offline Thanks Meter: 616 | e215L flash failed please correct this bug my phone is telcel mexico branded i try to read the flash from other phone in working state and same problem trying using repair mode ( flash ) and without this option and this is the result |
01-31-2009, 01:53 | #5 (permalink) |
Member: 103024 Status: Offline Thanks Meter: 616 | also tryed as m310 with usb also i tryed to flash the phone as m310 with usb and rj45 interface and same result check this pic also face this problem in your support forum http://www.nsdongle.com/forum/index....ic,9160.0.html |
02-09-2009, 08:30 | #8 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Juarez "Most Violent City" Age: 49
Member: 221355 Status: Offline Thanks Meter: 25 | I am also trying to flash Telcel E215l both with E210 cable and USB cable and I get the following: Loading S-Record File ... Loading S-Record File ... Power on mobile ! Loading flash loader (1/1) ... Sorry, an error has occured ! (ERR_FLASHTYPE) Press NEXT to continue... NsPro is updated and I am using comport 4. Please advice. |
02-13-2009, 07:44 | #9 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Belize
Member: 803361 Status: Offline Thanks Meter: 132 | Guess what...i unlock an E215L TELCEL mexico by choose M310 in Nspro and using E210 cable and press UNLOCK.... it worked Smiley Code: Entering Test mode... Preparing phone... Restarting Phone... Waiting for Phone... Entering Test mode... Waiting for Phone... Checking Security Type... Using Advanced MSL... Unlocking phone... Removing Simlock... Storing data... Restarting Phone... Operation successfully completed cheers...i didn't flash phone or do anything...i just got it from customer that just bought it...and i unlocked it using NSPRO... |
02-17-2009, 13:36 | #10 (permalink) | |
Junior Member Join Date: Jan 2008
Member: 689743 Status: Offline Thanks Meter: 7 | Quote:
is exactly what you wrote in the forum for ns pro, but what they do not realize is that the flash is not releasing the phone! | |
02-17-2009, 18:21 | #11 (permalink) | |
Member: 103024 Status: Offline Thanks Meter: 616 | Quote:
03-05-2009, 20:45 | #12 (permalink) |
Member: 221355 Status: Offline Thanks Meter: 25 | Tried to flash a E215l again with usb cable and Samsung Mobile usb port (com 10). I still get the following: Loading S-Record File ... Loading S-Record File ... Power on mobile ! Loading flash loader (1/1) ... Sorry, an error has occured ! (ERR_FLASHTYPE) Press NEXT to continue... Elco please advice. Have 5 phones that freeze on please wait. |
03-05-2009, 21:33 | #14 (permalink) |
Insane Poster Join Date: Mar 2009 Location: karachi
Member: 986684 Status: Offline Sonork: lock Thanks Meter: 11 | hi dear i know i see you post dear all modal is two hanging & Dead is flish is trobil if you have the power ic so replac is i am sure sole the trobil e250 there is 3 version ic is easy avabial frist check you hardwer thanx |
03-05-2009, 22:41 | #15 (permalink) | |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | Quote:
i think Flashing will solve the problem. br | |
The Following User Says Thank You to BouRRi_GSM For This Useful Post: |
E215L Flash File | alvaroc | NSPRO | 0 | 08-07-2009 22:11 |
***E215L flash need*** | plopez | UST Pro II | 1 | 07-19-2009 09:37 |
Cant read e215l flash | cesartefacto | UST Pro II | 2 | 07-19-2009 09:37 |
Rogers TU720 flash failed , Writing PBL operaion failed.,log inside | gebokecu | VygisToolbox | 2 | 05-26-2009 00:27 |
E215l flash type not supported | panafax_gsm | NSPRO | 1 | 03-08-2009 22:50 |
