11-03-2012, 15:32 | #1 (permalink) |
Freak Poster Join Date: Jun 2009 Location: chengdu,city
Member: 1048476 Status: Offline Sonork: nkjn Thanks Meter: 15 | I9300 4.1.1 repair signal successfully second,backup efs by Ns pro thord,update system to 4.1.1 forth,restore efs backup firth,now IMEI is 0049...... sixth,repair signal again.....everything will be ok. good luck,guys.Great team,Ns Pro |
The Following 6 Users Say Thank You to Eric_cn For This Useful Post: |
11-03-2012, 15:51 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | you dont need such complicated steps. Dont matter if the phone is 4.0.4 or 4.1.1 Just root it then write IMEi again. The phone will be OK with signal and everything... |
The Following 7 Users Say Thank You to Elco For This Useful Post: |
11-03-2012, 22:43 | #4 (permalink) |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | if the update is by OTA, no. If the update is by Kies or Odin, yes. |
The Following User Says Thank You to Elco For This Useful Post: |
11-04-2012, 03:05 | #5 (permalink) |
Member: 1048476 Status: Offline Sonork: nkjn Thanks Meter: 15 | but after update to 4.1.1 by odin,signal was gone,and IMEI/SN all normal.I tried to fix it again successfully,signal same....so I restore efs backup.then fix it and work. |
The Following User Says Thank You to Eric_cn For This Useful Post: |
11-05-2012, 12:58 | #9 (permalink) |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Make sure you write the original S/N on the phone when repairing IMEI. Also the IMEI must be a VALID IMEI. If you write IMEI 123456789012.. the GSM provider network wont accept the phone to register. |
11-06-2012, 15:58 | #15 (permalink) | |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
Contact me by yahoo messenger: [email protected] And i will help you to solve that problem. | |
