02-14-2016, 01:57 | #1 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2050764 Status: Offline Thanks Meter: 1 | Need help with NSPRO installation, NSPRO app not launching/opening I need help setting up with my NSPRO box. I'm pretty much really out of option here. I uninstalled it multiple times and was able to generate key multiple times after installations. I have all the drivers Installed. My problem is that when I try to launch the NSPRO app, it initialize then it just closes and nothing happens. Can you guys help? I set the app to run as admin. I even tried setting it up as compatibility mode on Windows XPsp3. My PC is running Windows 7 64 bit. I attached pictures of the device manager and the app loading however it just closes after it loads. |
02-17-2016, 21:02 | #4 (permalink) | |
Freak Poster Join Date: May 2013
Member: 1947667 Status: Offline Thanks Meter: 31 | Quote:
6.8.1v has a bug and its not working. Better to install 6.8.0 since its the last working version and supports up to Note 4s, S5's | |
03-11-2016, 23:48 | #8 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | It was allready mentioned: latest nspro version has a bug on win7 64bit causeing sw not to start, if you still want to use it you must set your pc to best performance settings from control pannel...it will look like win 98 |
The Following User Says Thank You to dragosgsm For This Useful Post: |
03-29-2016, 13:34 | #9 (permalink) | |
No Life Poster Join Date: Sep 2014 Age: 46
Member: 2260435 Status: Offline Thanks Meter: 118 | Quote:
