Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 12-15-2007, 20:38   #1 (permalink)
mohamed75's Avatar
Member: 102762
Sonork: 1583079
Thanks Meter: 186
Is It Normal To Have Corrupted Imei After Flashing U600?
HI
today i tried to flash u600 that was freezing at samsung logo i tried without repair mode and it didnot work,after trying with repair mode it fully worked with network and without restarting
what i wanna know why imei got corrupted?coz of using repair mode or what?and what will happen if i flashed another phone without repair mode?will it die or what?
thanks in advance
Old 12-15-2007, 23:46   #2 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,394
U100, U300,U600, E490, J600 phones must be flashed with repair mode.
Is very important to use flash files from NsPro support area. Other files may damage the IMEI on the phone.
Old 12-16-2007, 10:13   #3 (permalink)
mohamed75's Avatar
Member: 102762
Sonork: 1583079
Thanks Meter: 186
this is what i did,i used flash file from support then flashed the phone with repair mode,but i got corrupted imei while the phone is fully working
Old 12-16-2007, 12:00   #4 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
what firmware you used to flash that phone?
Old 12-16-2007, 12:41   #5 (permalink)
mohamed75's Avatar
Member: 102762
Sonork: 1583079
Thanks Meter: 186
JPGE2 but really i flashed first without ticking repair mode and phone kept on freezing at samsung logo then i used the same file but with repair mode ticked and phone worked.
to be specific i just wanna know why imei got corrupted after flashing, is it because i flashed it in the first time without ticking repair mode or anything else?
thx in advance,elco
Old 12-16-2007, 12:48   #6 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
thx in advance,elco
No. IMEI should not get damaged by flashing with normal firmware, even if you flashed the phone using normal mode.
The Following User Says Thank You to Elco For This Useful Post:
Old 12-16-2007, 13:21   #7 (permalink)
mohamed75's Avatar
Member: 102762
Sonork: 1583079
Thanks Meter: 186
thanks for caring mr elco
Old 12-17-2007, 16:58   #8 (permalink)
Member: 112674
Thanks Meter: 5
Hi,
I am trying to flash a U600 but keep getting this and then nothing:
Loading S-Record File ...
Power on mobile !
Loading setup loader (1/1) ...
Loading RAM (1/1) ...
It doesnt go any further.
Please help...
Old 12-17-2007, 18:20   #9 (permalink)
.:Rici:.'s Avatar
Member: 46817
Thanks Meter: 29
I have flashed U600 with no ticked reparir with no problem and is noth a firmware from support and imei ok but I have problem with Z240 no change to conect to phone with 3.7.3 and the old version I have unlocked with no problem and now noth work with new and old wath is the problem cable ok 100%
Old 02-25-2009, 02:18   #10 (permalink)
disel center's Avatar
Member: 299401
Sonork: facebook:Ahmad Majzoub
Thanks Meter: 233
ok i had been take the same proplem with u600
i solved that by flashing with u600,b
becuase that,s 3 virgen or tap,s of u600
thx&hope benefit 4 all
to be shore take this link
http://forum.gsmhosting.com/vbb/show...highlight=u600
Old 06-20-2009, 03:11   #11 (permalink)
Member: 1053607
hi ........am new to this forum.... i have U600 G locked with virgincan any one gimme a clean guide on how to flash and unlock the phone .... and which firmware to use and where can i get those firmwares which suit my U600 G....
Old 06-20-2009, 03:23   #12 (permalink)
Member: 502531
Thanks Meter: 896
just click unlock..
br,
Old 06-21-2009, 04:42   #13 (permalink)
Member: 1053607
can u gimme a clean description on how to unlock it or to flash it
Old 06-21-2009, 18:35   #14 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
-Start NsPro software and select U600
-Connect powered on phone to nspro box
-Click UNLOCK
DONE!!!
Is realy that hard ?
Old 06-22-2009, 19:49   #15 (permalink)
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 966
NS have some problem when flashing U600 even with repair mode, it seem can't restore back NV backup when flashing.
also Repair SN function dosn't help in many phone.
br
corrupt imei after flashing by hwk samibapy HWK 6 12-28-2008 08:39
is it possible to have 2 copys of a sim card in seperate phones...... rancid_beats Sim Cloning and Scaning 2 04-10-2005 17:56
is it possible to have one sim with two numbers at the same time? 1508 GSM Programming & Reverse Engineering 7 07-06-2004 00:18
Is it possible to have russian lang in mw930 batman1980 Infineon C16X M51 & ARM7 M52 BASED 2 10-15-2003 22:03
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.26716 seconds with 8 queries
