Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 10-28-2005, 11:35   #1 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,395
Nsdongle v3.8.0 test reports
PLZ test Nsdongle v3.8.0 Agere flashing and post the results here.
Nsdongle v3.8.0 work ONLY on Win 2000 and Win XP with minimum 128 Mb RAM
Old 10-28-2005, 12:09   #2 (permalink)
fonefun's Avatar
Member: 26187
Sonork: 100:77458
Thanks Meter: 290
Hi Elco
Having a few problems with z500 is just wont connect
i have had not problem on older versions
Old 10-28-2005, 12:19   #3 (permalink)
fonefun's Avatar
Member: 26187
Sonork: 100:77458
Thanks Meter: 290
for get that post above it works fine just a bad cable i had
Old 10-28-2005, 15:31   #4 (permalink)
Member: 122016
S410i phone not detected
Old 10-28-2005, 19:33   #5 (permalink)
Member: 6738
Sonork: 100.81405
Thanks Meter: 10
z140 error
it worked in earlier versinos.
now a window read out of memory
z140 vodaphone spain.
Old 10-28-2005, 19:52   #6 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Originally Posted by hridaya
z140 error
Working fine.Without any problem.
Old 10-28-2005, 23:24   #7 (permalink)
Member: 97242
Thanks Meter: 14
unable to flash d500 blinking with jaf, no problem to flash phone with serial cable, phone does not power on.
Old 10-28-2005, 23:36   #8 (permalink)
Member: 97242
Thanks Meter: 14
problem also with serial cable, after flash (done without problem, just log stops to update, but progress worked), no way to repair phone, always restart with samsung logo.
flashed with hwk without problem and phone is alive again.
Old 10-29-2005, 12:23   #9 (permalink)
Member: 6109
Sonork: 100.37432
Thanks Meter: 3,781
Having error during flash x480 with Nsdongle v3.8.0.
Old 10-29-2005, 13:01   #10 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
PLZ download Nsdongle v3.8.1 and try again.
Old 10-29-2005, 13:24   #11 (permalink)
Member: 33690
Thanks Meter: 3,398
3.8.0 Small Bug
Hi,
Could Not Be Able To Unlock E715 Phone. Tested Several Times But No Luck. So I Tested Version 3.8.1 Now And Phone Is Unlocked. For Your Info.
Old 10-29-2005, 14:08   #12 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
C200 /agere/ flashing also not work - loaders mismatch...
Old 10-29-2005, 14:25   #13 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Old 10-29-2005, 16:09   #14 (permalink)
randy_d4's Avatar
Member: 71246
Thanks Meter: 40
hi
@Elco,the problem is not in your SW,U R using too new flashdll.dll( ver 4.16)
the flash loader for X480 is for older version(4.14) of flashdll.dll
So paste ( replace )atached file in your NSDongle dir and all will work fine(tested with X480)!!
PS: maybe some of other agere models will not work( flashing) but need to test this!!
PS2: remove .txt
Old 10-29-2005, 16:42   #15 (permalink)
Member: 39069
Sonork: 100.1606677
Thanks Meter: 190
I didn have phone test yet but just have one question: Can we flash all agere models with normal flash(normal size) and full flash(big size) ?
Nsdongle v3.8.11 released : SGH-T309 fully supported Elco NSPRO 26 12-17-2005 03:51
Nsdongle v3.8.4 released Elco NSPRO 18 11-02-2005 22:33
***New version !!! Nsdongle v3.6.0 released*** Elco NSPRO 45 10-26-2005 18:15
Page generated in 0.23385 seconds with 10 queries
