problem with uart with i9300 Why i can`t connect S3 i9300 with uart cable, it`s the same i use with s3 mini and others working fine, but with i9300 allways refuse to connect (every i9300 i want to work), can`t repair imei. B.R. |
it has been well documented already mate. 6.7.3 has a problem with windows 7 and the uart cable. waiting foe Elco to fix it. lolly pop |
I use OS XP in all my computers, as i said, the cable work fine with other models but cant use, even i build another with 560k resistor but no have success. Need help with this. b.r. |
I must be mistaken regarding the operating system but im sure the uart error and the i9300 is due to the 6.7.3 update and from what I have read if you can find a full 6.7.0/1 or 2 im sure the uart error with the i9300 isnt present lolly pop |
I did repair IMEI i 9300 .Firmware 4.3 .Downgrade to 4.0.4 IMEI repair success.NsPro 6.7.3 . |
This proble i have since previous versions not only in last, is not the nspro versịn, is the cable in the i9300 |
neptun505 did you use uart calble? wich cble you use, original from nspro? or a build cable |
resistor 510k to 560k. Try to connect in series 470k + 68 k |
Downgrade also to 4.1.2 and you'll that work all. Br allumts |
The simply S7070 nspro uart cable? i`ll buy one. |
my cable is 100% correct I have also downgraded the phone tried again with different versions and same issue. I have also tried reading a efs from a working phone and writing that and tried to repair IMEI but nothing is working. anyone got this working or can test this and what version is working. |
BR allumts |
but if this is correct then why does 6.7.1, I have just installed 6.7.0 and testing now, I have also read that there is no need to use patch files all is needed is 4.1.2 rooted then do the repair. |
6.7.0 also not working as above cable 100% what else can we try can anyone confirm a working version. just getting Connecting to phone UART, operation failed. |
