03-17-2009, 21:46 | #1 (permalink) |
Freak Poster Join Date: May 2005 Location: italia Age: 55
Member: 144459 Status: Offline Thanks Meter: 67 | F480 freeze (not unlock v5.0.8) Phone Freeze not unlock whit version 5.0.8 (flash all firmware support area) press unlock and message: checking serial communication... Operation failed! tried to unlock in download mode: checking serial communication... Operation failed! is possible repair freeze?? thanks. |
03-18-2009, 08:46 | #4 (permalink) |
No Life Poster Join Date: Sep 2007 Location: iran-shushtar
Member: 592636 Status: Offline Thanks Meter: 674 | my brother do u sure f480 mybe thats f480L OR F480T CHECHING FIRMWARE WITH *#1234# |
The Following User Says Thank You to soshan For This Useful Post: |
03-18-2009, 08:48 | #5 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Bolton Age: 44
Member: 41976 Status: Offline Thanks Meter: 33 | hi! you can fix f480 freeze problem with easy unlocker. it will give you unfreeze code and also unlock codes good luck |
The Following User Says Thank You to wearephones For This Useful Post: |
03-18-2009, 13:45 | #6 (permalink) |
Member: 144459 Status: Offline Thanks Meter: 67 | tanks for all @usernome ... my phone is detected, tried with and without adapter @soshan ... is F480 @wearephones ... I do not have the easy unlocker ... only nspro mister elco ... you can implement read code ?? any idea ?? |
03-18-2009, 14:09 | #7 (permalink) |
No Life Poster Join Date: Oct 2008 Location: WHERE THE WORLD ENDS
Member: 885625 Status: Offline Sonork: 100.1589108 Thanks Meter: 2,432 | hi there restart your pc open ns pro software,connect phone to dongle make sure that your phone and ns pro is configured below port 10 follow the instructions,regards suunnyy br. |
03-18-2009, 14:21 | #8 (permalink) |
Member: 144459 Status: Offline Thanks Meter: 67 | nspro com port is COM9 not possible problem com port ... Sevice Jobs and flash WORK ... k: not work ripair imei, unlock. I am not the only one to have this problem. read the forum nsdongle.com/forum. |
The Following User Says Thank You to alerene For This Useful Post: |
03-18-2009, 14:55 | #10 (permalink) |
Freak Poster Join Date: Sep 2007 Location: UK
Member: 595700 Status: Offline Sonork: 100.1582336 Thanks Meter: 262 | f480 freez solution........ any samsung freez simple direct unlock again wed any tool or device (not code reader) problem solve tested more than 50 pcs no need flash ... enjoy.......... |
The Following User Says Thank You to sebha For This Useful Post: |
03-18-2009, 16:23 | #12 (permalink) |
Member: 595700 Status: Offline Sonork: 100.1582336 Thanks Meter: 262 | all samsung freeze solution bro mean is just press unlock botton ... unlock ur fone again........ tips about conect the fone try diffrent cable.. try diffrent pc ... or restart ur pc or estart ur nspro etc etc goodluck Last edited by sebha; 03-18-2009 at 16:32. |
03-18-2009, 20:13 | #15 (permalink) |
Member: 144459 Status: Offline Thanks Meter: 67 | full flash with bootfile ... successful power on phone with sim card ... Phone Freeze. nspto v5.0.8 ... pres unlock: checking serial communication... Operation failed! Tab Service Job: Reset Phone Code Reset SIM Lock Reset Phone Lock... Reseting Sim Lock... Operation successfully completed cable is OK full flash is OK com port is OK reset code is OK and now??? elco ... please solved this problem |
1202 Unlocking not working 2.0.8.3 | bluffmaster | HWK | 15 | 05-20-2009 18:05 |
NsPro v5.0.8 released: | Elco | NSPRO | 44 | 03-11-2009 05:24 |
as is the procedure to repair imxxxx Samsung i900 with nspro v5.0.8 | cristhian garci | NSPRO | 1 | 03-07-2009 11:05 |
NsPro v5.0.8 released: | tito millo | Service Products News & Updates | 0 | 01-28-2009 04:03 |
f480 freeze can't unlock help | el-safwa | Easy-Unlocker | 14 | 01-15-2009 00:36 |
