06-19-2010, 18:10 | #3 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Santo domingo norte villa mell
Member: 398011 Status: Offline Thanks Meter: 25 | in bb 8520 I`m trying to unlock one bb 8520 and here what the server says Connect powered on phone to cable... Reading phone info... Connected to server Calculating codes on server (this might take a while)... Error: Receiving data from server failed due to unknown error. Operation failed! |
The Following User Says Thank You to betina For This Useful Post: |
06-19-2010, 18:31 | #4 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
06-21-2010, 17:41 | #7 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 414704 Status: Offline Thanks Meter: 3 | Connect powered on phone to cable... Reading phone info... Error: Cannot connect to server. Check internet connection and firewall. Operation failed! The server not always working. I found only worked for me twice. Most days not working. But unlock samsung is OK. |
The Following User Says Thank You to deepocean For This Useful Post: |
10-29-2010, 16:03 | #9 (permalink) |
Junior Member Join Date: Nov 2008 Location: Commonwealth of Dominica
Member: 895403 Status: Offline Thanks Meter: 7 | Most times this error shows up on NsPro it is due to the security lock on the blackberry. Go to Options > Password > Disable Lock and try again. It works fine for me after that, only if the bb code server is down then the unlock code will return failed... Hope this helps... |
The Following User Says Thank You to dotybizz For This Useful Post: |
06-28-2011, 10:16 | #10 (permalink) | |
Junior Member Join Date: Mar 2010
Member: 1273039 Status: Offline Thanks Meter: 0 | Quote:
Thanks Bro helped me a Lot realy good work thanks | |
RIM Blackberry pinouts? | feketebarany666 | BlackBerry (RIM) | 2 | 03-26-2011 19:47 |
Blackberry PDA and GSM phone | Burnt Cobba | BlackBerry (RIM) | 11 | 09-08-2010 09:48 |
RIM Blackberry Unlocking | fuzionGSM | BlackBerry (RIM) | 16 | 12-02-2008 03:45 |
blackberry 7230 how to unlock? | ghosthacker | BlackBerry (RIM) | 27 | 02-13-2008 20:06 |
Looking for Blackberry 6230 unlock solution | loren | BlackBerry (RIM) | 5 | 03-29-2005 08:16 |
