Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 04-10-2014, 06:54   #106 (permalink)
ihack43's Avatar
Member: 2103848
Thanks Meter: 35
^^^ Yes there is a fix for this..u need spt box
Sent from my SM-N900P using Tapatalk
Old 04-10-2014, 15:23   #107 (permalink)
chaudhfa's Avatar
Member: 1590407
Thanks Meter: 145
Try doing efs reset using n9005 that wil work
Originally Posted by ihack43 View Post
i also have an n900a that another store brought me...he tried to write nv items from n900t.....baseband unknown so even tho the commands for diag work the phone is not readable...i've already tried writing nv items from clean n900a with no success..although just a few do write..im kinda stumped as to what to do next
sent from my sm-n900p using tapatalk
hey bro try doing a efs reset using n9005 it will fix the baseband and do super imei .... I had a n900t with same problem and i fixed using this method
Old 04-10-2014, 16:20   #108 (permalink)
ihack43's Avatar
Member: 2103848
Thanks Meter: 35
Worth a shot I'll try that and let u know..thanks for the tip
Old 04-11-2014, 02:59   #109 (permalink)
Member: 2006935
Thanks Meter: 4
I'm doing the note 3 and getting 4G/LTE
Old 04-11-2014, 03:11   #110 (permalink)
ihack43's Avatar
Member: 2103848
Thanks Meter: 35
^^^^It's always LTE unless ur doing something wrong .
Old 04-11-2014, 15:54   #111 (permalink)
chaudhfa's Avatar
Member: 1590407
Thanks Meter: 145
let me know how it goes because im sure it will work.. good luck
Old 04-11-2014, 23:48   #112 (permalink)
Member: 2076039
Thanks Meter: 648
Originally Posted by ecs87 View Post
UMM are you sure you tried to write the N900T NV Items onto the N900A? I did...it doesn't end well. You still have access to download mode and recovery mode but you cannot get into Android. It closes the System process if you can even get into the Android OS. Most of the time it hangs at the AT&T Logo until it reboots by itself and therefore stays in a bootloop.
I've flashed the build that it was on in Odin and it succeeded. I've wiped data/cache multiple times. I believe that the NV Items from the N900T "semi-hard bricked" my N900A. If ANYONE knows how to clear the EFS back to default on the N900A through Odin/Download mode PLEASE let me know. I see that the SPT box may be able to correct the EFS/NV Items through Download/Odin mode, but...I don't own one of these boxes...
I've fixed my issue. I created a .tar file in Odin that you should be able to flash in the CP tab to restore a phone that is semi-bricked from loading bad NV items. This should work for both the N900A and N900T. WARNING: This will turn your IMEI into "/00"
N900Xradiounbrick
Old 04-11-2014, 23:53   #113 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
N900Xradiounbrick
Hopefully with this people don't mix NVitems from different models ... sometimes they do work but sometimes you will have a No good phone ....
Anyways to the people have been messaging asking for the Galaxy S5 IMEI fix ... well I have good and bad news ... bad news is that we need to find UaRT connection ... good news is still repair the IMEI .... hopefully the next couple of days I'll have something for yall, Before I go for a vacation or from this ....
Sent from my SM-G900T using Tapatalk
The Following User Says Thank You to jusmejose For This Useful Post:
Old 04-25-2014, 20:53   #114 (permalink)
Member: 778123
Thanks Meter: 6
has anybody been successful in repairing n900t imei?
The Following User Says Thank You to leronew For This Useful Post:
Old 04-26-2014, 16:04   #115 (permalink)
Member: 2175435
Wink
YES I HAVE. I CAN CONFORM tmobile N900T IMEI REPAIR WITHOUT CORRUPTING 4G/LTE USING SPT BOX.... I know a lot of people are having issues.. if anyone needs me to write the detailed post let me know.. due to the lack of the guides out there people tend to have issues..
thank you spt team.
Old 04-29-2014, 03:49   #116 (permalink)
Member: 2094866
I fixed my phone. Thanks guys!
Sent from my SM-N900T using Tapatalk
Old 04-29-2014, 04:52   #117 (permalink)
Member: 727582
Thanks Meter: 5
Yup please write the detailed post @ahmadnassar there will be less confusion for allot of the member...thanks
Old 06-01-2014, 02:45   #118 (permalink)
Member: 2190868
I have this device and my imei was recently repaired is there a way i can use tether my carrier is metro pcs im running 4.4.2 anything else that may be needed let me know
Old 07-29-2014, 05:28   #119 (permalink)
Member: 1738947
hi jose can you please help me with a samsung sm-n900t imei repair please , i have riff box can u please help me
Old 07-29-2014, 16:48   #120 (permalink)
Member: 1738947
hel with a sm-n900t stuck in uart conection with octopus box , if i restart the phone the box will be read but imei write fail error come in a sec please help me
Page generated in 0.25797 seconds with 8 queries
