Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 10-05-2012, 20:16   #1 (permalink)
Wideon2000's Avatar
Member: 144806
Thanks Meter: 22
samsung s3 00449 imei [SOLVED]
i have a samsung s3 i9300 it rooted this mobile then tryed to unlock via nspro
now the imei is 0044 and will not work on my network
i tryed to repair the imei with nsp pro and it allway fails
if there any one can tell me what to do via skype or msn as im really worryed
im on 6.4.1 and have a old c3300k cable and i change the resistor to 560k so it now same as a s7070 cable please help need help now if possible
Old 10-05-2012, 20:23   #2 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,395
Fallow the software instructions to unlock/repair IMEI and the phone will be OK.
Use I9300 Root file from NsPro support area and select I9300 Rooted on NsPro.
Old 10-05-2012, 20:36   #3 (permalink)
Wideon2000's Avatar
Member: 144806
Thanks Meter: 22
100% tryed with patch with out rooted and it errors same every time what firmware is best to be installed as i try a few and all the same the one think im a little unsure of is *#9090# then i see (2) speed and press that and see it 115200 is that right
but still same operatin failed
Old 10-05-2012, 20:46   #4 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
nobody can understand your sentence.
use points "." and commas "," and marks "?, !,..." to make your sentence more clear.
Old 10-05-2012, 20:57   #5 (permalink)
Wideon2000's Avatar
Member: 144806
Thanks Meter: 22
ok
tryed the patch
and tryed rooted
both same results ( operaiton failed )
on software 6.41 it asks to add the mobile to s7070 cable (560k) but then the software asks to keyin *#9090#
and set software on the mobile to 115200 this is option 2 so do i just click on options 2 and then it set is that the right way to do this step
i have tryed s7070 cable with 560k res and also c3300k with 150k res both same will not complete
cant really explain any more if anyone know how to resolve this i would be happy to do remote admin ( teamviewer ) as there not really a 100% way to sort this problem out
all i know is z3x is way behind on this as its impossible to repair ( change ) imei with that tool
my nspro is regged till next of next month so subbed up
Old 10-05-2012, 21:33   #6 (permalink)
Wideon2000's Avatar
Member: 144806
Thanks Meter: 22
Preparing Phone...
Resetting IMEI...
Connecting to phone UART...
Operation failed!
Old 10-05-2012, 22:21   #7 (permalink)
Wideon2000's Avatar
Member: 144806
Thanks Meter: 22
Preparing Phone...
Resetting IMEI...
Operation failed!
somebody echo please answer this question
some body
Old 10-05-2012, 23:35   #8 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
contact me by yahoo messenger: [email protected]
I will help you to fix that phone.
Old 10-06-2012, 02:04   #9 (permalink)
Wideon2000's Avatar
Member: 144806
Thanks Meter: 22
ok im going to download the flash file on the server then patch and try again if i fail ill add you to yahoo
also i made a new cable with a 560k resistor fitted lets ope that sorts it
can i would it be adviced to reflash the .pit file too
and for people like me what dose the .pit file really do
Old 10-06-2012, 02:42   #10 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Use Root file and select I9300 ROOTED on NsPro
Dont use patch file.
Patch file is not compatible with latest i9300 firmwares.
Old 10-06-2012, 04:31   #11 (permalink)
Wideon2000's Avatar
Member: 144806
Thanks Meter: 22
right update
just installed
I9300XXBLFB_I9300OXFBLF1.zip firmware on support
then rooted
i9300_root.zip
then after a few times of trying ...... bang bingo the imei was restored
i have to say make sure your useing a s7070 cable and not a c3300k cable
if not very easy to make 3 wires and i used a 560k resistor
pin out are on the support site ......
p.s make sure that the cable is instered right into then uart port on the box
and after reflashing firmware 4.0.4 i did do a vol down and home button and power button to get to recovery mode then did a factory reset and davic partistion reset ...... quite simple
then root and make sure cable fully inserted add details to software and bingo
Happy Camper
thanks for your help party people and ekco
keep up the rapid updates and keep it real
WideOn
The Following User Says Thank You to Wideon2000 For This Useful Post:
Old 10-27-2012, 16:57   #12 (permalink)
Member: 1441172
Thanks Meter: 2
managed to change imei from dummy 0049...all as above but have to put *#7284# in and choose "modem" at top and "pda" at bottom.
Old 11-14-2012, 18:00   #13 (permalink)
topline's Avatar
Member: 85139
Thanks Meter: 68
Waiting for phone...
Checking if phone is Rooted...
Root Access Granted!
Preparing Phone...
Resetting IMEI...
Operation failed!
help my imei 0049
Old 11-14-2012, 18:18   #14 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Preparing Phone...
Resetting IMEI...
Operation failed!
help my imei 0049
PLZ make sure that you are using NsPro S7070 RJ45 cable.
NsPro work ONLY with cables made for NsPro.
Cables made for other box dont work with NsPro.
C3300K cable will NOT work with i9300.
If the cable is OK, NsPro can write IMEI on the phone, without any problem.
Old 12-01-2012, 01:03   #15 (permalink)
Member: 64869
Need help
Hi ELCO,
I have one I9300 with imei 004999XXXXXXXX (killed by Z3X Box), i try to flash with i9300xxblh1_i9300oxfblh1 firmware and rooted with I9300 Root v2, but when i try to repair IMEI with Original IMEI and SN :
Preparing Phone...
Resetting IMEI...
Using Advanced MSL...
Bypasing Security...
Setting Serial Number...
Writing IMEI...
Resetting Phone...
Operation successfully completed
But still 004999XXXXXXXX IMEI problem ?
I used S7070 NSPRO cable and i also try to repair EFS but nothing...
Can you help me please ?
Thanks
HotKamz
Page generated in 0.29612 seconds with 9 queries
