Successfuly Repair Imei SIII I9300 4 Attachment(s) :)Wow Nspro Tem bOM bOM UPDATE Successfuly Repair Imei SIII I9300:cool: |
wahooo nic working bro NSPRO good tool |
Repair Imei SIII I9300 2nd phone With Prof 4 Attachment(s) :eek:Hay I M Repair 2nd Phone With Prof Nice work NS Pro Preparing Phone... Resetting IMEI... Connecting to phone UART... Reading MSL... Using Advanced MSL... Bypasing Security... Writing IMEI... Resetting Phone... Operation successfully completed:cool: |
Hi, I got same work to do tomorrow, if activation of box is done, so I have few questions if you don't mind : what cable did you use ? how did you flash patch file ? is there specific step I should know to not waste most time ? Thank you, BR |
What tool do I need for the fix, killed customers device and need to fix Imei = NaN, will nspro save the day? |
Does it solve no EFS partition problem? In my case it won't even restore backup image I had with efspro |
The i9300 patch with Jelly Bean XXDLI5 firmware ? |
After imei repair, can we flash or update the original software without losing the network, anyone tried..? Thank you. |
I M Repair IMEI and After Update Phone Online No Problem N successfully Update |
r u sure after updating u didn loose network. ??????????? |
Hay Bro Quote:
if u change imei and after that update firmware and dont loose network.then nespro first in the world. there is no box sport not loose network after update firmware. |
can i use any samsung imei for change imei i9300? or anything else? please help me. thanks |
Preparing Phone... Resetting IMEI... Connecting to phone UART... Using Advanced MSL... Bypasing Security... Setting Serial Number... Writing IMEI... Resetting Phone... Operacao com sucesso concluida |
Better use I9300 Root file from NsPro support area to root the phone Then select "I9300 Rooted" on Nspro to perform IMEI Write operation. . |
