02-13-2008, 23:19 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Canary Islands Age: 53
Member: 17351 Status: Offline Thanks Meter: 41 | I just can get 3.8.6 to work! and followed it 100%. I have even uninstalled Jaf in case that is affecting it! But whatever I do It always says there is a problem installing this device. I have totally run out of idea's. I have reinstalled, rebooted a million times but always message NSPro Port not detected! Maybe it is to do with the the NS Pro Port I am using number 4(well below 10(. Which drivers should I use here? Either way I have followed everything and after hours of it im giving up. But if someone can give any other suggestions in the meantime I would be grateful! As I say I have followed the above and every other suggestion! |
02-13-2008, 23:28 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In a point from Universe! Age: 40
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | This is true:is very unstable this box.I have 3 pc's at my workplace and nspro it doesn't work on any of them.In change at my home on my computer is working OK.So,now I have 4 computers at the service.This was the single method that I can use NsPro without problems.I've instaled it on a single computer and it's working. Regards! |
02-14-2008, 17:34 | #3 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Near the sea... Portugal Age: 48
Member: 120120 Status: Offline Sonork: 100.1592092 Thanks Meter: 234 | Quote:
02-14-2008, 19:46 | #4 (permalink) |
Member: 17351 Status: Offline Thanks Meter: 41 | It worked fine with the 3.8.0 version This one just will not work. If you are saying I have to buy a new pc just for one software that must be a joke?? It has and is driving me mad though! |
02-14-2008, 20:07 | #5 (permalink) |
No Life Poster Join Date: Dec 2001
Member: 8102 Status: Offline Thanks Meter: 118 | Try this if not done so already Uninstall all NSpro Delete the folder NSPro Download it again from NSPro site Install 3.8.6 When asking for drivers MANUALLY point them to the folder Thats how I did it and worked for me |
02-14-2008, 20:23 | #6 (permalink) |
No Life Poster Join Date: Jul 2004 Location: YODAFON
Member: 75392 Status: Offline Sonork: 100.81199 Thanks Meter: 136 | I did the same, but with the new version I have "failed to initialize com port". I did a fresh xp install just for Nspro, but still the same... very frustrating... thank g0d i have Samsung Rocker and HWk still... this new version is bullshlt |
02-19-2008, 11:22 | #9 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 42
Member: 122774 Status: Offline Thanks Meter: 15 | Iīve got to install NSPRO in other PC who I donīt have anything installed there and now it works realy good. and itīs the only way i got to do u700 a L760. hope it helps!! BR |
02-20-2008, 21:01 | #10 (permalink) |
Member: 75392 Status: Offline Sonork: 100.81199 Thanks Meter: 136 | it worked 2 days, till I had to install a blackberry desktop suite, and it set the comport for blackberry to the same port as nspro com port (com 5), so today I had "com bort not available" again. i finally uninstalled Blackberry suite, and it works again, but like as I said, if you don't have a PC just for NSPRo, you will encounter problems often.... |
02-20-2008, 21:12 | #11 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Always Here Age: 37
Member: 333494 Status: Offline Sonork: 100.1607053 Thanks Meter: 190 | For me 3.8.6 work fine but not with Jaf. 1st. comuter i install BB5 box ., SETOOL., and NSPRO., and others comuter i install JAF., HWK., MT BOX., CRUSER., and SMART CLIP. and work fine!!! you need only 2 comp. |
02-21-2008, 07:18 | #12 (permalink) |
Member: 75392 Status: Offline Sonork: 100.81199 Thanks Meter: 136 | I have Jaf, bb5box, thunderstorm, hwk (one of them), typhoon dongle, sagdd on a secont pc, NSpro, UB, other two HWK-s, scdr2, infinity, furious, martech, Rockerdongle, Setool, vygis on the first one, and all was ok till I installed blackberry drivers.... I cannot understand why blackberry took over the NSpro's comport.... |
02-21-2008, 11:57 | #13 (permalink) |
Member: 75392 Status: Offline Sonork: 100.81199 Thanks Meter: 136 | One more interesting thing: Yesterday evening before I turned off my pc, Nspro was working fine. Today moning first app I started was Nspro but "failed to initialize com port". again. I'm kinda pissed off.... |
cant get shell version 1.6 to work | geeza | Multi-Box | 7 | 01-09-2009 09:33 |
Cant Communicate with fone on 3.8.6 | winston_006 | NSPRO | 12 | 02-26-2008 15:11 |
Elco plz hpl me.....3.8.6...Failed to initialize COM port! | MOURAD | NSPRO | 1 | 02-12-2008 17:05 |
recovery for K750 R1CA021 CID49 in 8,6 not work | Roni1976 | SonyEricsson (USB-Smart) | 2 | 06-02-2006 23:50 |
Can you get this A300 software to work??? | ibn Bilal | VLSI, Conexant, Skyworks and Old Models | 0 | 10-20-2001 20:15 |
