02-11-2013, 22:47 | #1 (permalink) |
Junior Member Join Date: Oct 2012
Member: 1825704 Status: Offline Thanks Meter: 0 | T889 after unlock shows no sim card I'm trying to unlock a T889. followed direction carefully and after it unlocks, it says no sim card. T-mobile sim still works fine. Please help. Thanks, KB |
02-11-2013, 23:23 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | PLZ check the sim card. That problem dont have anything to do with unlocking. Clean the sim card contacts then connect the card to phone. |
02-12-2013, 04:23 | #5 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: places I repair phones
Member: 621698 Status: Offline Thanks Meter: 405 | Quote:
because I never had any problem like this using NSpro before I had my NSpro since 2008 and since then I never since this kind of problem with NSpro unlocking! Most likely it has a hardware issue on simcard reader. Open the phone and check the connector on the board it might be disconnected because all Samsung Galaxy, all simcard reader is replaceable ( meaning it can detach from mother board not like many cellphone is solder on cellphone. | |
02-13-2013, 00:59 | #7 (permalink) |
Member: 1825704 Status: Offline Thanks Meter: 0 | Phone doesn't ask for unlock code. It just says no sim card. I tested with T-mobile and Simple sim, it works fine. I have no problem with nspro either. but this is the first t889 i do so just wondering if there might be a glitch or something wrong with this phone |
02-13-2013, 02:15 | #8 (permalink) | |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
Test the same sim card on other phone that use micro sim (ex. s3) | |
02-14-2013, 23:03 | #9 (permalink) |
Member: 1825704 Status: Offline Thanks Meter: 0 | all sim cards were tested and work fine. Customer already came and picked up the phone. I think it is because of the phone. I have another T989 today and it works great. However, the option T989 Uart didn't work though. Thanks!!! |
02-15-2013, 00:08 | #10 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Macedonia
Member: 1671934 Status: Offline Thanks Meter: 247 | Then reflash the phone. First type *#06# to see if IMEI is correct and ok. Then reflash. Tru full reset first. Try *2767*3855# maybe will do the trick. |
