05-05-2006, 16:49 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | No is NOT a bug. Like i posted before, you must connect powered off phone to Z500 NsBox cable. Phone must power on by himself. Then everything will be OK. |
05-06-2006, 11:07 | #3 (permalink) |
Freak Poster Join Date: Sep 2004 Age: 50
Member: 81553 Status: Offline Thanks Meter: 23 | sorry, i didn't make myself clear. i need to repair the imei number and when i get info the imei all i get is <=<=<=<=<=<=<=< and 0000000000 in the bluetooth id when using usb cable. serial cable does not work either |
05-06-2006, 14:35 | #4 (permalink) |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | To be able to repair IMEI on Z500 you must use NsDongle Box + Z500 RJ45 cable for NsDongle Box. And DONT short 2,3 pin on COM port. |
s3100 did not connected with ust is it supported for unlock or not | neeraj1st | UST Pro II | 2 | 03-15-2010 23:23 |
Please add se j132 to unlock with imei , not work with serial!!!!!! | svchost | Seking Server | 3 | 04-25-2009 17:23 |
z500 not connect to soft | mrunlocker | UST Pro II | 1 | 12-12-2007 14:46 |
HELP...P990 NOT connecting with DCU-60 cable with power on | CHAPRAN | Universalbox | 0 | 08-15-2007 13:12 |
I do not obtain to make update of smart-clip, is not connected with the site? | Fernandowap | Smart-Clip | 7 | 11-01-2004 07:39 |
