![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2001 Location: U.K Age: 54
Member: 4611 Status: Offline Thanks Meter: 68 | Z540 flash failure? Phone just dispays a diag menu now? On it all I have is page 1/3 *: picture #:next blah blah blah Never seen this menu before, but there should be enough info for those who have to help me. If I go to download mode from this menu the screen goes yellow. If I switch the phone on manually holding 9 and power then then phone screen goes blue, control panel sees it correctly, but ns reports the error "reading aknowledge failed" Any ideas???? Cheers |
![]() | #2 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2005 Location: in the line of fire..
Member: 157118 Status: Offline Thanks Meter: 156 | i had same prob...i wanted to unlock it but no joy.so i flashed it..fone died.then i tryed with Z540DZFEI.fone is alive but still locked.better alive than dead. |
![]() | #3 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2004
Member: 97600 Status: Offline Thanks Meter: 97 | you can try these http://translate.google.com/translat...l%3Den%26lr%3D with this http://www.iwant1.pwp.blueyonder.co.uk/zflash.rar |
![]() | #4 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2005 Location: Portmore, Jamaica Age: 53
Member: 160245 Status: Offline Thanks Meter: 21 | Z540 Flash I am not having success unlocking this z540 which shows phone freeze when an incorrect chip is inserted. I flashed successfully with nsPro i even flashed the bootloader and usb boot sections. All went well however phone freeze still there (just as expected) anyone know how to get rid of the phone freeze. Otherwise when i perform the unlock procedure it always fails. Sometimes it restarts the phone. ?? |
![]() | #5 (permalink) |
Major Poster ![]() ![]() Join Date: Mar 2006
Member: 249060 Status: Offline Thanks Meter: 2 | guys i think found solution press * an # a few times let the phone format an do its thing but put phone on charge for hour or bit more an keep pressing * an # an then put phone on to ns pro but change port to com9 an try flash phone must work i suffere whole day bu got it working after change to com9 but go to nspro support to verify the changes to com9 although it does not say y should hange to com9 but it works an charge battery while phone is doing its own format. good luck |
SGH-Z540 Flash and Software | oddyone | QUALCOMM Models (3G) | 5 | 02-27-2014 11:02 |
Z540 Flashing ready! | T.S.T | TST Dongle | 15 | 05-11-2007 07:58 |
Too Elco When Ns Pro Support V804SS - Z540 Flash And Unlock | POP_JUB | NSPRO | 11 | 10-08-2006 20:24 |
z540 flashed.... | pumapimo | QUALCOMM Models (3G) | 7 | 08-23-2006 17:47 |
Where can I download Z540 Flash File? | gtotop | Samsung Flashers, Software, Firmware. | 0 | 06-17-2006 17:14 |
