d750-k750 serial cable Hi, im using serail cable for k700 etc. What pinout can i use to put a d750 connetcot to t28 serial cable? or only usb possible? I want too out a k750 connecter to t28 serial cable, On t28 cable 4 wires connected. thanks Sjakie |
sir I think its is not possible since the k750 runs only on usb . have u try the setools its good sir |
Hi, solder a 750 too siemens usb cable, workimg fine with logs. But cannot work with UFS setool card combination? regadrs Sjakie |
Can you tell me how to build a K750 cable from a Siemens USB cable? I have been hunting for it for months.... Regards, Csarlee |
Just a short note if it helps. I use TotalMultiserver to unlock / repairs SE's if totally necessary. I never had a USB cable for K750 but I have the USB to COM cable which I use for my NSDongle Software. I have a ps2 connector which I use to unlock K750 via my SuperClip and to connect the K750 to pc I simply use this ps2 connector with my USB to COM cable. And it does work a treat. Its also works with my serial cable which I use for my Vygis (LG Unlocking Software). So at the end of the day, there is no need to buy a special cable for the K750 as long as you have a ps2 connector for it, which most unlockers should treasure as a prize possession lol. |
It is okay you have a PS2 connector, but the root cause of this is inside the cable. My original problem was that I had a T28 cheap/china whatever service cable which had only 4 wires to go to the phone. Then I asked around about how to build a SERIAL cable for new SE phones and those schemas I got here haven't worked at all. Now I figured out that my T28 cable utilizes a 5 V technology because it is based on Max232 IC, so I gonna build a 3,3 V based multi interface and try with that one... Csarlee |
