02-04-2005, 14:48 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Age: 57
Member: 14515 Status: Offline Sonork: 100.77248 Thanks Meter: 15 | Flashing problem with PBB (solved) I had a special flashing problem a few hours ago. I had to flash my friend's N6100 but I always got error MCU didn't boot or something. I haven't seen that before so I checked my Twister service battery I used for it. I found a 10K resistor betwwen GND and BSI. I checked my N6230 service battery and found 68K resistor between GND and BSI. I replaced 10K to 68K and all flashing problems solved. BR Roy |
02-04-2005, 21:17 | #2 (permalink) | |
No Life Poster Join Date: Jul 2001 Location: Inside Raskal pocket Age: 54
Member: 5325 Status: Offline Thanks Meter: 8,448 | Quote:
Best regards, Zulea | |
02-05-2005, 07:35 | #3 (permalink) | |
No Life Poster Join Date: Jul 2003
Member: 33804 Status: Offline Thanks Meter: 22 | Quote:
WBR | |
02-05-2005, 17:30 | #4 (permalink) |
Freak Poster Join Date: Jul 2002 Location: PA Age: 45
Member: 13453 Status: Offline Thanks Meter: 3 | Hi, I bought pbb box a week ago and still can use to flash any phone until right now....always got mcu did not boot or bad mcu id checksum errors. Do you think I should remove all the resistors from the cable ???? BR |
02-06-2005, 16:08 | #7 (permalink) |
Member: 13453 Status: Offline Thanks Meter: 3 | I checked all my cables , and i found out that's there's no resistors in all my cable in the bsi line... only resistors at between gnd and bsi. But I finally succeded flashing using pbb, only not perfect, always got mcu ack error in the middle of the process. And what makes it more strange is I HAVE TO USE 6V 500mAh to flash a phone !!!!!!!!!! I already tried all voltage, 7,5V;8V;9V; event 12V all can't work, always got mcu id checksum or mcu didn't boot error. With 6V I can flash phone, but still got errorr in the middle off procces ( MCU did not ACK )................ here's the log Reading data from phone Reading phone information Reading product type Reading HW version Reading product code Reading PSN Get flash file names Reading IMEI Reading flash settings from file(s) Detecting FLS4 FLS4 detected FLS Licenses remaining 1000 Starting flash... Detecting FLS4 FLS4 detected Initializing prommer Detecting flash device... Detecting FLS4 FLS4 detected FLS4 found Flashing image FLS-X Initialization done Licences remaining: 1000 Erasing Flash... Erasing: 5% Erasing: 10% Erasing: 15% Erasing: 20% Erasing: 25% Erasing: 30% Erasing: 35% Erasing: 40% Erasing: 45% Erasing: 50% Erasing: 55% Erasing: 60% Erasing: 65% Erasing: 70% Erasing: 75% Erasing: 80% Erasing: 85% Erasing: 90% Erasing: 95% Erasing: 100% Time Taken to Erase 105.872 Start programming flash memory... Programming: 5% Programming: 10% Programming: 15% Programming: 20% Programming: 25% Programming: 30% Programming: 35% Programming: 40% Programming: 45% Programming: 50% Programming: 55% Programming: 60% Programming: 65% Programming: 70% Programming: 75% Programming: 80% Programming: 85% Programming: 90% Programming: 95% Programming: 100% Programming done!!! Time Taken to Flash 44.284 Total Blocks ca.332 After MCU SW flashing delay3000ms C:\Program Files\Nokia\Phoenix\products\RH-9\cp_pW_05.350 FLS-X Initialization done Licences remaining: 1000 Erasing Flash... Erasing: 5% Erasing: 35% Erasing: 70% Erasing: 100% Time Taken to Erase 13.529 Start programming flash memory... Error! MCU did not ACK Flashing failed. ANyone got solutions ??? BR, |
02-06-2005, 16:35 | #10 (permalink) |
Member: 14515 Status: Offline Sonork: 100.77248 Thanks Meter: 15 | I tried it and worked fine without resistors but I think you should try 3,3K in BSI line and 68K between BSI and GND. This cable works fine with other boxes too. I'm sure 6V 500mA is not enough for flashing maybe you should find a stabilized power supply which can 7-8V and at least 1A. BR Roy |
flash problem with pbb | babaphone | Phoenix Black Box | 0 | 12-06-2005 18:26 |
flash problem with pbb | babaphone | Phoenix Black Box | 3 | 12-05-2005 10:06 |
flashing problems with pbb | babaphone | Phoenix Black Box | 0 | 10-20-2005 13:53 |
New problem with PBB and 7280??????? | Virginia | Phoenix Black Box | 4 | 04-27-2005 03:57 |
Problem with pbb !!! | florin_m | Phoenix Black Box | 2 | 01-26-2005 11:57 |
