02-28-2006, 02:46 | #2 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Beograd,Serbia Age: 54
Member: 3101 Status: Offline Thanks Meter: 6 | SW update procedure when using USB cable: A. Alive phone (phone in normal mode. Make sure that the phone is not in offline mode) 1. Plug in USB cable (from PC to phone) 2. When phone asks mode, select “default mode” 3. Select USB connection from Manage Connections 4. Scan the product 5. Use Flashing -> Firmware Update to update the phone B. Dead phone flashing (phone does not go to Normal Mode) using Phoenix version 2005.44.7.123. Because of problem in this Phoenix version you need first use alive phone and USB connection to get product codes visible to UI. Then follow the following steps: 1. Close connection (use Manage Connections. Select NO CONNECTION, use arrow key to put it as first in the list. Click Apply) 2. Remove the USB cable from the phone 3. Connect dead phone to USB cable 4. Select product code from the list 5. Select Dead phone USB flashing check box 6. Press start 7. When program status text asks you to press phones power button do it and flashing will be done -After flashing there is no USB connection, so if you have more dead phones, you can flash those just putting new phone to USB cable -If you are flashing some other phone models, then you have to make an appropriate connection from Manage Connections |
03-03-2006, 01:07 | #5 (permalink) |
Member: 3101 Status: Offline Thanks Meter: 6 | Run phoenix,menage no connection,open rm-56 ,go to flash, choose dead phone flashing ,put usb cable ,start and power up the phone manualy when phoenix starts to count,install drivers as prompted and be patient after several times of trying phoenix will start to flash.Latest version is 3.66. |
How to flash N95 with this box you not update FIA and how flash new phone now ?? ?? | wgmmmx | Federal One | 0 | 06-22-2007 19:44 |
how to flasher 6270 with PBB? | MODELTIME | Phoenix Black Box | 15 | 12-13-2005 22:32 |
How to flash d500 with a usb flash cable? | solid_snake | SWIFT Platform | 1 | 10-11-2005 19:37 |
how to flash D418 with Opti flash? | Rocco | Trident/AGERE Platform | 1 | 03-30-2005 02:54 |
