07-23-2006, 22:53 | #1 (permalink) |
Crazy Poster Join Date: Jul 2006
Member: 317194 Status: Offline Thanks Meter: 1 | N91 dead after flashing??? i´m really new on this sector with workin on Phoenix. Tried to change firmware on a Nokia N91 from 1.11.003 to 1.10.003. Update startet, but after a while window popuped and says that i cant downgrad firmware. Now N91 stays dark. if i try to connect nothing happens. can´t switch N91 on. Nothing. Compltly dead? How can i reactivate N91???? Any key combination to start it in update mode??? Please help!!!! Thanx in advance |
07-23-2006, 23:23 | #3 (permalink) |
Member: 317194 Status: Offline Thanks Meter: 1 | Cable 7pin? Used the cable delivered with N91. can i buy this "7pin cable" or is there a instruction to build it? sorry, but i´m new on this sector. last time i flashed a siemens mobile 5 years ago - it was much easier! ;-) Thanx!! |
07-23-2006, 23:42 | #4 (permalink) |
Member: 317194 Status: Offline Thanks Meter: 1 | ok, searched the internet for J.a.f 7pin cable. It is a box. am i right this box is connected to the PC and from there a normal usb cable (as deliverd with N91) is used???? so, no chance to get back my N91 to life? please wright a small description for a rookie....... rgds critical |
07-24-2006, 12:38 | #5 (permalink) |
Member: 317194 Status: Offline Thanks Meter: 1 | ok, i searched for cable and found several "7pin cables". But a technician at Vodafone Germany says there is no 7pin cable for Nokia N91, because N91 has only mini-usb. Not the typical nokia connector. he says that there is no 7pin cable for N91. now i´m really confused..... any ideas???? rgds critical |
08-10-2006, 08:27 | #6 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | beleive me there is 7pin cable. it is service cable with batery adaptor , N91 have pins (for 7pin cable) under batery !! Pali i have here N91 for flashing too, but only usb cable, dont know if it is safe to flash it with PBB, because Pbb killed my 6280 !!! Pbb doesnt support flashing 6280 ! so maybe same problem with N91. |
08-10-2006, 10:39 | #7 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Slovakia BA Age: 51
Member: 25110 Status: Offline Thanks Meter: 79 | You are asking, why is your N91 dead? Cos you downgraded it. NEVER DOWNGRADE BB5. Only fbus flashing heps to you now, but not with PBB (try JAF, MTbox, unibox....) With PBB and latest phoenix you can flash N91 OK, but only by USB. |
08-10-2006, 11:26 | #8 (permalink) | |
No Life Poster Join Date: Aug 2002 Age: 57
Member: 14515 Status: Offline Sonork: 100.77248 Thanks Meter: 15 | Quote:
BR Roy PS: Yesterday flashed an N91 too. Works fine. | |
08-10-2006, 14:49 | #9 (permalink) |
Member: 7586 Status: Offline Thanks Meter: 11 | @Roy i flashed 6280 about 3-4 months ago, there was older version 128 i think ! this one killed my phone. Today i update to latest version 148 (??) -as Foony writes me to use, and i flashed N91 via USB without problem ! Of course never use older version. (firmware release ) Pali |
08-10-2006, 19:10 | #10 (permalink) | |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Quote:
http://www.one-stop-factory.com/ Go Here & Search for N91 Key Word | |
n91 dead after flashing with 8gb file | SATISH | Nokia Base Band 5 ( BB-5 ) | 11 | 04-29-2009 08:26 |
N91 dead after flashing error | ::.imeimate.:: | Universalbox | 2 | 07-04-2006 12:47 |
