01-31-2005, 16:18 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 51
Member: 57138 Status: Offline Thanks Meter: 4 | License Count Problem |
01-31-2005, 21:13 | #4 (permalink) |
Freak Poster Join Date: Sep 2002 Location: indonesia Age: 44
Member: 15338 Status: Offline Thanks Meter: 2 | i try with nokia 2280,3586,3586,3105,and many more,i used griffin cable,3105 same with 6100,2280,3586,3585,6585,i made by my self, ithing the pin out same with gsm the deference once just the location of the pin out,i hope u can solve our bigest problem master zulea???btw thank's alot for replay our posting and when pbb can write imei(RPL)??? |
01-31-2005, 21:50 | #5 (permalink) | |
No Life Poster Join Date: Jul 2001 Location: Inside Raskal pocket Age: 54
Member: 5325 Status: Offline Thanks Meter: 8,448 | Quote:
Problems with CDMA can be solved, but need few time to make experiments. Best regards, Zulea | |
01-31-2005, 23:16 | #7 (permalink) | |
Can you give me some hint how to check if Authority ID in DCT3 TDMA phones is OK or not, but without any TDMA network? There is some selftest reported error? Best regards, Zulea | |
01-31-2005, 23:46 | #8 (permalink) |
No Life Poster Join Date: Jun 1999 Location: Germany
Member: 233 Status: Offline Thanks Meter: 36 | Hi Zulea In two weeks I back in Florida, so I can make some Test with TDMA and CDMA DCT3 and DCT4 phones, but I have only PKD and FPS8. Her in Germany I have also some DCT3 TDMA phones and a TDMA Tester. Adapter for the most CDMA/TDMA allready finished. Jan |
02-01-2005, 01:26 | #9 (permalink) | |
No Life Poster Join Date: May 2003
Member: 27881 Status: Offline Thanks Meter: 11 | Quote:
Well, I donīt think is possible to check without an active TDMA network.... WT self Tests will not help, coz you will never got any network to syntonize...... If you have some beta version, I can test it for you. If you need, PM me and we try to sort it out.... Regards | |
02-01-2005, 11:41 | #11 (permalink) | |
Member: 57138 Status: Offline Thanks Meter: 4 | Quote:
Succes flashing 3585i,6585,6225. Only need pnoenix R & D for flashing cdma with PBB | |
02-01-2005, 17:13 | #13 (permalink) |
Freak Poster Join Date: Jul 2002 Location: PA Age: 45
Member: 13453 Status: Offline Thanks Meter: 3 | @alif30 which one I should install first to use the phoenix r/d sw ? Today I installed phoenix r d sw after phoenix service sw and got many errors when i open the program. @Yohan plese let me know if u succeded flashing cdma phone using phoenix r n d sw, u can tell me directly via extension phone directly to 570.... ok jack ?? |
02-01-2005, 17:29 | #14 (permalink) |
Member: 57138 Status: Offline Thanks Meter: 4 | I also experience of the same problem a lot of error, become the me try several times succeed. In fact for the flash of cdma needn't wear the pnhx r&d but its result is dissatisfactory often. Hopefully succeed |
02-01-2005, 17:53 | #15 (permalink) |
Member: 13453 Status: Offline Thanks Meter: 3 | @alif which one did u installed first to use the r d sw ?? In my expererience if I installed the original phoenix service sw first before i install the the r d version the dongle will become undetected...... Or u just installed the r d only, and didn't install the original sw ?? |
Error , License file problem | nadeem_75 | Easy-Unlocker | 2 | 01-07-2010 12:49 |
activation count problem please help me | ::. zine .:: | FuriousGold | 4 | 12-07-2008 18:11 |
Counting problem at support area | Cobbysyms | UST Pro II | 2 | 08-18-2007 22:10 |
boot count problem | Devils-thoughts | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-06-2001 12:49 |
boot count problem?????? | GsMen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-08-2001 08:32 |
