01-24-2005, 23:41 | #1 (permalink) |
Freak Poster Join Date: Dec 2002 Location: Poland Age: 45
Member: 19001 Status: Offline Thanks Meter: 45 | New User: Can't flash with PBB :( I have problem with PBB, Phoenix is working, i can instal it, it start ok. I can read phone (backup and restore user data), set contrast.... everything it is working but, i can't flash phone , I always get this same error. My PBB is powered 7,8V 700mA and it is stable (i check this with a multimeter) also with phone conected and powered, I changed power for atmega, now it is connected directly to USB 5V (I have many problems with phoenix, like registration errors,error loading component ), after that change phoenix working more stable.But I still can't flash phones (tested on 6310i and 6100). I tired this software on 2 PC with this same result, also phoenix was instaled a couple times. |
01-25-2005, 02:23 | #2 (permalink) | |
No Life Poster Join Date: Jul 2001 Location: Inside Raskal pocket Age: 54
Member: 5325 Status: Offline Thanks Meter: 8,448 | Quote:
Just make an online update and all will be ok. If you need, use Force update option. Best regards, Zulea | |
01-25-2005, 06:23 | #4 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
There need be maded one more small modification, but isn't my right to make suggestion ... WBR, DebeliaMark, BG | |
01-25-2005, 09:32 | #5 (permalink) | |
Your problems is totaly different. Usualy "Command failed" comes from old/wrong/bad update and an new online update using Force update option solve this problem. For your problems: Recommended power supply adapter is 7,5 volts and more than 500mA. ACP-8X is NOT working, because give only 5,7 volts! In FLS-4S this regular charger (ACP-8X used in old FLS-4) was also changed to ACF-8. This ACF-8 give more voltage (volts) and more supply current (mA) than regular charger ACP-8X. But this ACF-8 is available ONLY for Service Points (included in FLS-4S package). If you use right power supply, you do not need to make any modifications inside PBB to get power from USB. Also try to NOT use any LPT cable extension. Regarding your second problem (Vpp) try use RIGHT power supply, and check again. If still errors, your boxes have something wrong and must contact your reseller for replacement. Best regards, Zulea | |
01-25-2005, 10:09 | #8 (permalink) |
Freak Poster Join Date: Feb 2003 Location: CHINA Age: 50
Member: 23042 Status: Offline Thanks Meter: 5 | error: Flashing failed. Error occured during the flashing procedure. Low level error description: MTI error or error from some other component Tips: None HRESULT 0x800400ef (-2147221265) stop 13% |
01-25-2005, 11:04 | #9 (permalink) | |
01-26-2005, 00:35 | #10 (permalink) |
Member: 19001 Status: Offline Thanks Meter: 45 | Still not working PBB updated again with option force update - update successful. Anotcher PC, new instal of phoenix, PBB connected directly to LPT port in PC. Always this same error... |
01-26-2005, 02:49 | #11 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | @kowal.techgsm For me, it looks like box firmware update problem... but anyway, Have you done this? http://forum.gsmhosting.com/vbb/showthread.php?t=177953 if so and still not work, try this: 1. Open chinese data cable and remove the resistor on the BSI line. BSI should now ....be directly connected to the PCB. Do NOT remove resistor between GND and BSI. ....So now you should have cable with 1 resistor inside, close it and try again. if still now work, maybe you should check PCB of PBB and see if all components are connected ok. check atmega128 legs too 1 by 1 as well as other ICs. All phones give same error? What phoenix version are you using? Update FLS-4 Driver to 2.04 as well. B.R. X-Shadow |
01-26-2005, 16:04 | #12 (permalink) | |
Insane Poster Join Date: Sep 2001 Location: spain Age: 65
Member: 6559 Status: Offline Thanks Meter: 1 | Quote:
I sended my log file via email Thanks | |
01-27-2005, 22:23 | #13 (permalink) | |
Member: 19001 Status: Offline Thanks Meter: 45 | Quote:
http://forum.gsmhosting.com/vbb/showthread.php?t=177953 In chinese data cable BSI line is directly connected to the PCB. Resistor between GND and BSI is 68K. But also is there one between Btemp and GND- 47K And Yes, all phones give same error phoenix "phoenix_service_sw_2004_46_4_75.exe" instaled and updated to "phoenix_service_sw_2004_46_5_76_upd.exe" FLS-4 Driver "DRV_FLS4_204.exe" I also try this: " After playing with deskey options in Control Panel, the errors messages suddenly disappeared. Try this: Tip # 1: Go to Control Panel --> DESKEY --> DK2/DK38 TAB --> put a check on Exclusive Mode (all options here should now have a check) --> click Advanced --> select "Advanced - Hardware Timing" Tip # 2 When loading phoenix, I make sure that no phone is attached. After phoenix has successfully loaded, you can now attach the phones that you wish to service. " Nothing changed Tested on 6310i, 6100 and 6510. Tomorrow I will check all connections from and to atmega B.R. kowal.techgsm | |
New E50 can't unlock with BB5BOX new FLASH IC. ANY UPDATE ?? ?? | wgmmmx | MT-BOX | 5 | 12-16-2007 18:10 |
need manual usb flashing with PBB ? | ccipo | Phoenix Black Box | 3 | 12-30-2005 13:54 |
T630 - with new RSA - can't flash modem | GSMBlade | Cruiser Suite | 12 | 05-13-2005 06:57 |
Die 6020! Don't flash with PBB! | Gsm-W | Phoenix Black Box | 0 | 03-25-2005 10:35 |
Rolis can't flashing the nokia3410 :( so where i can get jordic ? | the_frightener | Nokia Multimedia | 16 | 01-06-2004 22:29 |
