Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Sonics Box
Old 05-10-2005, 20:47   #1 (permalink)
ASHIF's Avatar
Member: 8353
Sonork: 113276
Thanks Meter: 335
5 locks closed after flashing k500i
i flashed k500i with r2ae flash ...it was in blinking problem....sonicsbox flashed it completely ..when power on k500i it says insert correct sim card...now its all locks are closed..........i tried to write gdfs but it stops at 82%.......
Tell me what to do?
Old 05-10-2005, 20:53   #2 (permalink)
arash111
Guest
Posts: n/a
Member:
resurrect phone and unlock/repair, in sonicslanguage write gdfs when repairing.
Old 05-11-2005, 01:24   #3 (permalink)
Member: 38039
Thanks Meter: 6
Yes, as what the_microe said, tick "write gdfs when repairing", select k500i gdfs file in the "gdfs or script file" field, then press UNLOCK/REPAIR button.
best regards
Old 05-11-2005, 11:49   #4 (permalink)
Member: 104917
Thanks Meter: 8
Had the same error with k500 too. [but no locks] Flash bin+fs ok, but gdfs also stops at 82%.
Seems to be a bug in Setool or bad gdfs. Read a gdfs from a friends k500.
No problem to repair with this gdfs.
Regards
Anders
Old 05-11-2005, 21:29   #5 (permalink)
ASHIF's Avatar
Member: 8353
Sonork: 113276
Thanks Meter: 335
i read gdfs from another ok k500i and successfully write to phone but no success....when i tick "write gdfs when repairing" phone goes back to its blinking problem condition........... :-(
Old 05-12-2005, 01:17   #6 (permalink)
Member: 38039
Thanks Meter: 6
@ashifrocker, reveal[SW]
pls post the log and attach the gdfs here, i'll try to help you.
How to copy the log:
Click the right button of the mouse in the inter-active window of SONICS, you'll see a menu, select "copy to clipboard" and click.
best regards
Old 05-12-2005, 01:30   #7 (permalink)
arash111
Guest
Posts: n/a
Member:
when you have a phone which is blinking, upload gdfs and write it, simple -
if you have a 5locks closed phone, resurrect it ''write gdfs when repairing'' and upload gdfs _ then press unlock/repair.
Old 05-12-2005, 12:39   #8 (permalink)
Member: 15395
Thanks Meter: 22
As per experience do not use the GDFS file included in the CD...
GDFS from CD stops on 82%
Tried reading from good unit...and flash it in ur 5 locks close unit...works fine...
If u will notice file size is different from file got from CD...
Old 07-23-2005, 11:09   #9 (permalink)
chuckzster's Avatar
Member: 139924
Thanks Meter: 6
yes ive experienced it also with setool....writting gdfs solves the 5 locks problem...........
K850 5 locks closed after using EMMA Crazy_ratata Sony Ericsson 10 07-15-2008 17:54
w200i 5 locks closed after unlock with SE Full unlocker handystoregsm Sony Ericsson 1 07-10-2008 10:09
W200i 5 locks closed after unlock, please help! handystoregsm Sony Ericsson 5 07-08-2008 14:18
W200i 5 lock closed after unlock(cid52)in ub CHAPRAN Universalbox 6 08-11-2007 07:36
T610 4 locks closed after flash with DIV8.0 raino Sony Ericsson 60 08-28-2003 16:05
Page generated in 0.17347 seconds with 9 queries
