05-10-2005, 07:47 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Manila, Philippines Age: 41
Member: 137104 Status: Offline Thanks Meter: 8 | Configuration Error...Solved!!! Make sure ur running the Main Program together with the folder included in when installed in ur PC... Normal installation extracts all files to the Program Files directory under Sonic folder... Make sure that TPA Folder exsist... This folder includes the customized.xml file to complete phone... This will cure the Failed to open file while finalizing the phone... For a complete Setup installation ask ur reseller... Or i'll be uploading it later in my website... www.s23quiapo.epinoy.com Note: File will be password protected... |
05-10-2005, 18:10 | #3 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Manila, Philippines Age: 48
Member: 15395 Status: Offline Thanks Meter: 22 | Just want to thank Redeagle for the info regarding this matter, Jsut figured it out this morning from his post regarding the use of the customized.xml for finalizing phones... I'm working on how to change data on the said file for customizing... More Power and *** Bless... |
05-11-2005, 01:52 | #4 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: dasma cavite Age: 46
Member: 78367 Status: Offline Thanks Meter: 11 | Quote:
bigyn m nmn ako ng login pass s powerflaher/ pra s slaver lng.... slmat.. sorry for my language..... | |
05-11-2005, 02:02 | #5 (permalink) |
No Life Poster Join Date: Feb 2003 Location: www.X-SIM.me Age: 45
Member: 22955 Status: Offline Sonork: 67574 - Not use it Thanks Meter: 584 | Hehehehee... Really cannot belive this . Heeheehe... Till now you couldn't finallise the phones. Heheheheh... Great update Mr. Redeagle, you are the best progamer in your street for sure! @s23_M.C.P.Q Mate, you made a hell of a job! Best Regards! |
05-11-2005, 02:33 | #7 (permalink) |
Member: 22955 Status: Offline Sonork: 67574 - Not use it Thanks Meter: 584 | I really made a decision not to post here any more.Also, have strong belives that Zfrank will finally close this 'cheating section' . But mate, this was soo funny that I couldn't belive. Hehehehhee... |
05-11-2005, 10:38 | #8 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: Philippines
Member: 17609 Status: Offline Sonork: 100.64817 Thanks Meter: 1,694 | Quote:
Have you test S700i or other SE RSA phone? | |
05-11-2005, 10:55 | #10 (permalink) | |
When you openwith costumization.xml to notepad you will see this: <?xml version="1.0" encoding="UTF-8" ?> - <customization> - <info> <pcr-registered>2004-05-05T15:45:00</pcr-registered> <pcr-created>2004-05-05T19:28:20</pcr-created> <created-by>23032100</created-by> <cda-number>CDA102286/8</cda-number> <cda-revision>R2A</cda-revision> <model>K700i</model> <country>Generic</country> <operator>Generic Trade</operator> <language-variant-name>WorldWide</language-variant-name> <allowed-language>ar</allowed-language> <allowed-language>he</allowed-language> <allowed-language>ru</allowed-language> its for K700i only so i started this thread http://forum.gsmhosting.com/vbb/showthread.php?t=205704 Last edited by Ron2pet; 05-11-2005 at 11:07. | |
05-11-2005, 11:19 | #11 (permalink) |
No Life Poster Join Date: Apr 2001 Location: รำมว&#
Member: 3956 Status: Offline Sonork: galletto3 rules :D Thanks Meter: 55 | hi yes, customization file is from k700 however it works for all se models since is generic, you can also edit it in order to change details (customization, version..) in phone I donīt see any problem with the file... best regards Invisible |
05-11-2005, 11:39 | #12 (permalink) | |
Freak Poster Join Date: Dec 2004
Member: 97346 Status: Offline Thanks Meter: 14 | Quote:
I want to test sonics for flashing and costumization. I flashed S700i_Hongkong ....ok Costumization................... Serial number: #MB0XXX Sonics connected. Chip Id: 0x80000301 CID detected: 29 Speed: 921600 bps Header acknowledged. Prologue acknowledged. Payload acknowledged. Loader version: 041008 0857 LLECXC1326738_COMPACTFLASHLOADER R2M Flash loader running in phone. OTP status: 0, locked: 1, CID: 29 PAF: 1, IMEI: 35454800345318 Chip Id: 0x80000301 CID detected: 29 Speed: 921600 bps Header acknowledged. Prologue acknowledged. Payload acknowledged. Loader version: 040319 0923 LLECXC1326739_COMPACTCERTLOADER R2E CSloader version: 040615 1629 GOHCXC1327364_COMPACT_SEMC_CS_LOADER_R2B executing CS loader startup... loader startup: executed executing CS loader filesystem startup... loader filesystem startup: executed executing CS GDFS startup... loader gdfs startup: executed executing CS loader unlock... loader unlock: executed CS loader prepare finished. Will excute script now... Done Phone detached Time elapsed: 27 secs But my phone is "Configuration error .....again" I have Cruiser ( i know that cruiser can fix this), but I want to test SONICS..... | |
05-11-2005, 12:17 | #14 (permalink) |
Member: 3956 Status: Offline Sonork: galletto3 rules :D Thanks Meter: 55 | hi check config file you are using is ok overwriting yours with original (from install one), then you can flash only lenguaje and be sure to check "brand" option (in order to customize phone), once done should be ok best regards Invisible |
05-12-2005, 02:47 | #15 (permalink) |
Junior Member Join Date: Aug 2004 Age: 45
Member: 77252 Status: Offline Thanks Meter: 0 | sir, so far in using sonics box i haven't encountered it yet when i flash s.e. units including s700i i only encountered it when someone bring it to me, i just simply flash it n its all ok i'm using win98SE and all is working smooth and ok regards |
w550 Sony ericsson Mobile Error Configuration error Please Contact Your Network Oppe | Ravi Potdar | Sony Ericsson | 12 | 10-26-2014 13:17 |
W810 Configuration error 100% solved by HWK | alamgir80 | HWK | 1 | 12-03-2008 13:45 |
W800 Configuration Error Solve By Hwk | smart_mobile | HWK | 0 | 03-03-2006 19:52 |
Configuration error K700i | molecule | Sony Ericsson | 6 | 10-10-2004 18:57 |
mcu id configuration error??? | proxy_gsm | Federal One | 0 | 02-28-2004 09:35 |
