08-16-2011, 18:06 | #17 (permalink) |
No Life Poster Join Date: Jun 2006 Location: salina cruz, oaxaca, mèxico Age: 59
Member: 296918 Status: Offline Thanks Meter: 122 | Zmem1120 Finally i conected the phone Zonda ZMEM1120 from Telcel Mèxico, this is the log from pinfinder Code: software version: 1.26 platform: MT: MT62xx (autodetect) cable type: 1x20 (L20A) mode: Slow searching adapter at COM10 (115200)... too many retries adapter found, version: 2000 Loading platforms configuration... Initializing platforms... Press and HOLD phone Power button now ! pins: 20, plain power/activation cycles: 1/7 power-off delay: 20 start Rx/Tx: 1/1 detecting pins... 19200 fixed 19200 fixed CPU: MT6226 result: Rx:6 Tx:7 time required: 46 sec Trying to Power-On... Power is On Power is On saved: zonda_ZMEM1120 Code: COM10 [VCP0] selected module v3.75 Device: Zonda-ZMEM1120 Checking data, wait... advanced flash detection enabled Action: "user code" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:5F30:436D status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: MASS1_MXZONDA_PCB01_GPRS_MT6226_S01.MASS1_07A_W07_28_MP_V22.BIN project-id: MASS1.07A.W07.28.MP.V22, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Zonda-ZMEM1120_MASS1_MXZONDA_PCB01_GPRS_MT6226_S01.MASS1_07A_W07_28_MP_V22__ffs... file saved: C:\Archivos de programa\InfinityBox\MModule\Zonda-ZMEM1120_MASS1_MXZONDA_PCB01_GPRS_MT6226_S01.MASS1_07A_W07_28_MP_V22__ffs_20110816-114530.B0E.bin flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: EC257E25082501:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 6 min 28 sec Remove/Install battery now ! thanks for your help B.R. |
The Following User Says Thank You to foo_men For This Useful Post: |
12-23-2021, 10:17 | #20 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Quetta
Member: 728887 Status: Offline Sonork: 100.1625878 Thanks Meter: 18 | COM9 [ProlificSerial0] selected module v4.48 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:9F19:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done 115200 Set baud Done Initialize bootcode Done device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... ..usb bootloader detect (phase #2)... ..usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: T01C_TELCEL_PCB01_GPRS_MT6223P_S00.ZMTN610_SW_V01_ 16.BIN project-id: ZMTN610_SW_V01_16, 00000000 code offset: 00000000 ffs offset/size [01]: 00A00000/005F0000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00A00000 standard ffs/eeprom offset confirmed: 00A00000 detecting ffs/eeprom size... ffs/eeprom size: 00600000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00A00000-00FFFFFF firmware area: 00000000-009FFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ......startup code area #2 is absent detecting ffs/eeprom structure pass 1... .......................ffs/eeprom: detect std location pass #1... ........................................ffs/eeprom: detect ext location pass #1... ......................................ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... .search sec info#1 finished Check firmware integrity Done Check firmware content Done reading: T01C_TELCEL_PCB01_GPRS_MT6223P_S00.ZMTN610_SW_V01_ 16__ffs... file saved: C:\InfinityBox\MModule\T01C_TELCEL_PCB01_GPRS_MT62 23P_S00.ZMTN610_SW_V01_16__ffs_20211223-140628.B0E.bin flash: 98000300000001:2BEA0000000000 Backup required data Done detection procedure, wait... detection procedure completed Patch required data Done Special operation Done flash: 98000300000001:2BEA0000000000 Write: ffs Write Done Finalization Done Finished, time used: 12 min 3 sec Remove/Install battery now ! UNLOCK DONE ON SOFTWARE BUT PGONE IS STILL LOCKED |
12-25-2021, 16:16 | #22 (permalink) |
Member: 728887 Status: Offline Sonork: 100.1625878 Thanks Meter: 18 | Zonda zmtn610 unlock done but still locked module v4.48 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:9F19:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done 115200 Set baud Done Initialize bootcode Done device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... ..usb bootloader detect (phase #2)... ..usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: T01C_TELCEL_PCB01_GPRS_MT6223P_S00.ZMTN610_SW_V01_ 16.BIN project-id: ZMTN610_SW_V01_16, 00000000 code offset: 00000000 ffs offset/size [01]: 00A00000/005F0000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00A00000 standard ffs/eeprom offset confirmed: 00A00000 detecting ffs/eeprom size... ffs/eeprom size: 00600000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00A00000-00FFFFFF firmware area: 00000000-009FFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ......startup code area #2 is absent detecting ffs/eeprom structure pass 1... .......................ffs/eeprom: detect std location pass #1... ........................................ffs/eeprom: detect ext location pass #1... ......................................ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... .search sec info#1 finished Check firmware integrity Done Check firmware content Done reading: T01C_TELCEL_PCB01_GPRS_MT6223P_S00.ZMTN610_SW_V01_ 16__ffs... file saved: C:\InfinityBox\MModule\T01C_TELCEL_PCB01_GPRS_MT62 23P_S00.ZMTN610_SW_V01_16__ffs_20211223-140628.B0E.bin flash: 98000300000001:2BEA0000000000 Backup required data Done detection procedure, wait... detection procedure completed Patch required data Done Special operation Done flash: 98000300000001:2BEA0000000000 Write: ffs Write Done Finalization Done Finished, time used: 12 min 3 sec Remove/Install battery now ! ZONDA ZMTN610 UNLOCK DONE BUT STILL LOCKED |
12-27-2021, 12:22 | #25 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | it may be many reasons, f.e. firmware has hardlock or anything else. You can try to flash phone with another firmware but no any guarantee about result. You can try and see rsult. |
==== FREE DOWNLOAD ==== site updated | cimbalo | GSM Mobile Links | 31 | 04-29-2012 20:43 |
5130 updating | mudboy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 09-02-2011 12:58 |
updating nokia software version | zbomberman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 02-06-2001 21:47 |
Need solution for 3210 v5.01 | tati | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-20-2000 21:55 |
