Old 08-16-2011, 17:02   #16 (permalink)
foo_men's Avatar
Member: 296918
Thanks Meter: 122
Yes, it is a 20 pin cable connector, same as samsung E210.
I`ll try as you say, and i`ll post results.
B.R.
Old 08-16-2011, 18:06   #17 (permalink)
foo_men's Avatar
Member: 296918
Thanks Meter: 122
Zmem1120
Finally i conected the phone Zonda ZMEM1120 from Telcel Mèxico, this is the log from pinfinder
software version: 1.26
platform: MT: MT62xx (autodetect)
cable type: 1x20 (L20A)
mode: Slow
searching adapter at COM10 (115200)...
too many retries
adapter found, version:  2000
Loading platforms configuration...
Initializing platforms...
Press and HOLD phone Power button now !
pins: 20, plain
power/activation cycles: 1/7
power-off delay: 20
start Rx/Tx: 1/1
detecting pins...
19200 fixed
19200 fixed
CPU: MT6226
result: Rx:6 Tx:7
time required: 46 sec
Trying to Power-On...
Power is On
Power is On
saved: zonda_ZMEM1120
And this is from MModule:
COM10 [VCP0] selected
module  v3.75
Device: Zonda-ZMEM1120
Checking data, wait...
Action: "user code"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
chip: 0031:5F30:436D
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: EC257E25082501:2AEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
Initialize Done
====>  Set baud ...
115200
Set baud Done
====>  Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====>  Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
rom info detection finished
rom info ver: 04
sw version: MASS1_MXZONDA_PCB01_GPRS_MT6226_S01.MASS1_07A_W07_28_MP_V22.BIN
project-id: MASS1.07A.W07.28.MP.V22, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
ffs/eeprom address assigned: 00E00000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: Zonda-ZMEM1120_MASS1_MXZONDA_PCB01_GPRS_MT6226_S01.MASS1_07A_W07_28_MP_V22__ffs...
file saved: C:\Archivos de programa\InfinityBox\MModule\Zonda-ZMEM1120_MASS1_MXZONDA_PCB01_GPRS_MT6226_S01.MASS1_07A_W07_28_MP_V22__ffs_20110816-114530.B0E.bin
Backup required data Done
====>  Patch required data ...
detection procedure, wait...
detection procedure completed
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
Write: ffs
Write Done
====>  Finalization ...
Finalization Done
Finished, time used: 6 min 28 sec
Remove/Install battery now !
thanks for your help
B.R.
The Following User Says Thank You to foo_men For This Useful Post:
Old 12-22-2021, 15:52   #18 (permalink)
zubairkhann's Avatar
Member: 728887
Sonork: 100.1625878
Thanks Meter: 18
plzzz give me your contect
Originally Posted by YellowBoss View Post
@TECNICELL2007
Thanks a lot ! Your test-report is really important for us !
Old 12-22-2021, 16:20   #19 (permalink)
Member: 1043909
Thanks Meter: 60,926
Run software, connect Rx/Tx/Gnd cable to phone and do the job.
In case of problem post here software log text
Old 12-23-2021, 10:17   #20 (permalink)
Member: 728887
Sonork: 100.1625878
Thanks Meter: 18
COM9 [ProlificSerial0] selected
module v4.48
Device: _Autodetect MT6205-6239 NOR
Action: "sp-unlock"
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:9F19:000C
status: FF
Boot Done
flash: 98000300000001:2BEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
115200
Set baud Done
device parameters detection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
..usb bootloader detect (phase #2)...
..usb bootloader (chip) is absent
rom info structure: [standard] type (05)
TCL-ID is absent
rom info ver: 05
sw version: T01C_TELCEL_PCB01_GPRS_MT6223P_S00.ZMTN610_SW_V01_ 16.BIN
project-id: ZMTN610_SW_V01_16, 00000000
ffs offset/size [01]: 00A00000/005F0000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00A00000
standard ffs/eeprom offset confirmed: 00A00000
detecting ffs/eeprom size...
ffs/eeprom size: 00600000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00A00000-00FFFFFF
firmware area: 00000000-009FFFFF
detecting startup code area #2...
.................................................. .................................................. .................................................. .................................................. .................................................. ......startup code area #2 is absent
detecting ffs/eeprom structure pass 1...
.......................ffs/eeprom: detect std location pass #1...
........................................ffs/eeprom: detect ext location pass #1...
......................................ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok: element #1
.search sec info#1 finished
reading: T01C_TELCEL_PCB01_GPRS_MT6223P_S00.ZMTN610_SW_V01_ 16__ffs...
file saved: C:\InfinityBox\MModule\T01C_TELCEL_PCB01_GPRS_MT62 23P_S00.ZMTN610_SW_V01_16__ffs_20211223-140628.B0E.bin
Write: ffs
Write Done
Finalization Done
Finished, time used: 12 min 3 sec
UNLOCK DONE ON SOFTWARE BUT PGONE IS STILL LOCKED
Old 12-23-2021, 17:53   #21 (permalink)
Member: 1043909
What is the text at phone LCD when you power it on with sim card?
Old 12-25-2021, 16:16   #22 (permalink)
Member: 728887
Sonork: 100.1625878
Thanks Meter: 18
Zonda zmtn610 unlock done but still locked
module v4.48
Action: "sp-unlock"
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
115200
Set baud Done
TCL-ID is absent
rom info ver: 05
TCL-ID is absent
ffs/eeprom chip: 00
Write: ffs
Write Done
Finalization Done
ZONDA ZMTN610 UNLOCK DONE BUT STILL LOCKED
Old 12-25-2021, 16:56   #23 (permalink)
Member: 1043909
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 12-27-2021, 11:55   #24 (permalink)
Member: 728887
Sonork: 100.1625878
Thanks Meter: 18
invalid sim
Invalid sim
when i insert sim
Old 12-27-2021, 12:22   #25 (permalink)
Member: 148515
Thanks Meter: 19,534
it may be many reasons, f.e. firmware has hardlock or anything else.
You can try to flash phone with another firmware but no any guarantee about result. You can try and see rsult.
Old 12-27-2021, 16:07   #26 (permalink)
Member: 728887
Sonork: 100.1625878
Thanks Meter: 18
can you provide ma any firmware
Old 12-27-2021, 17:09   #27 (permalink)
Member: 148515
Infinity support area => / flashfiles / ~infinity-legacy / Zonda /
==== FREE DOWNLOAD ==== site updated cimbalo GSM Mobile Links 31 04-29-2012 20:43
5130 updating mudboy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 09-02-2011 12:58
updating nokia software version zbomberman Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 02-06-2001 21:47
Need solution for 3210 v5.01 tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 01-20-2000 21:55
Page generated in 0.33886 seconds with 10 queries
