Old 12-03-2007, 03:49   #1 (permalink)
Member: 130995
Thanks Meter: 35,230
03 Dec 2007: "ChineseMiracle" v2.06 released
"ChineseMiracle" v2.06 uploaded in support area (no need to use Internet connection, standalone security area repair, no need to make ASK/RPL calculation via server):
.security area repair improved (21 new firmwares supported)
New flash files uploaded in support area:
now more than 12 Gb zipped (so it's about 20 Gb unzipped) flash files for different "Chinese" models
Anycool-D66+_CPU1_E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_ 1_16m_En_Ru_Cn_Ar
Anycool-D66+_CPU2_E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_ 1__E553AGENT_F1_E553_GSM_MT6205B_DN.01_5_4m_En
CM_Cect-C828_KINGER_6226_PCB01_GPRS_MT6226_S01.GA08_BT_OVE RSEA_06A_W06_40_1_0_16m_En_Ru_Fr_Th_Vn_Cn_Ar_w_eep rom
CM_Cect-E818_M500TV_S106_PCB01_GPRS_MT6226_S01.00_0_Pocket-PC-6600_En_Vn_16m_En_Vn
CM_Cect-N82_CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_10_26B_B XD_L7EN_103_070921_LD-TR0_OV0_SS75_CTF_BT_16m_En_Ru_Fr_Th_Vn_Farsi_Ar
CM_Cect-V668_U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B27_ 16m_En_Ru_Fr_Es_Th_Vn_Pt_Ar
CM_Mobile-TV-Center_U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B1 2_16m_En_Ru_Fr_Es_Indonesia_Th_Vn
CM_Nokia-6300_2x5pin_MIKI26_05C_PCB01_GPRS_MT6226_S01.V20_5 6_16m_En_Cn_Cn_Th_Es_Fr_Ru_Ar_Pt_Vn
CM_Nokia-N658-K818_LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06 _48_06_16m_En_Ru_Fr_Th_Vn_Ar_w_eeprom
CM_Nokia-N658-K818_LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06 _48_09_16m_En_Ru_Fr_Th_Vn_Ar
CM_Nokia-N70-RM-84_TELSDA26_05C_PCB01_GPRS_MT6226_S01.BASECODE_16m _En_Ru_Fr_Th_Vn_Cn_Ar
CM_Nokia-N70_Nokia-N72_TELSDA26_05C_PCB01_GPRS_MT6226_S01.BASECODE_16 m_En_Ru_Fr_Th_Vn_Cn_Ar
CM_Nokia-N73_TELSDA26_05C_PCB01_GPRS_MT6226_S01.BASECODE_16 m_En_Ru_Fr_Th_Vn_Cn_Ar
CM_Nokia-N81_LSH300_YS8347B16_PCB1P0_V1P2P1_16m_En_Ru_Cn
CM_Nokia-N82-CPU1_E558_JQ3AFPA_E558_GPRS_MT6226_S01.01_1_16m_En _Ru_Fr_Ar_w_eeprom
CM_Nokia-N82-CPU2_E558_JQ3AFPA_E558_GPRS_MT6226_S01.01_1__E558A GENT_S2_E558_GSM_MT6205B_DN.01_6_2m_En_w_eeprom
CM_Nokia-N91_TELSDA26_06A_PCB01_GPRS_MT6226_S01.V9_V0_2_16m _En_Ru
CM_Nokia-N92-2sim_N618_PCB01_GPRS_MT6227_S01_16m_En_Cn
CM_Nokia-N92_E553_X8PAF5C_E553_GPRS_MT6226_S01.V23_01_1_16m _En_Ru_Fr_Th_Vn_Ar
CM_Nokia-N95-1x5pin_T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS _V0917A_16m_En_Ru_Fr_Es_Indonesia_Th_Ar
CM_Nokia-N95-2sim_N618_PCB01_GPRS_MT6227_S01.1_16m_En_Fr_Th_Ar
CM_Nokia-N95-slider_N618_PCB01_GPRS_MT6227_S01_16m_En_Th_Ar
CM_Nokia-N95_N618_PCB01_GPRS_MT6227_S01.1_16m_En_Th_Ar
CM_Sands-A303-CPU2_E00_2003.07.30i_MAUI.05B.W06_4m_En_w_eeprom
CM_Sands-A303_TELSDA26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W 06_16_MP_V28_16m_En_Ru_Fr_Th_Vn_Ar
CM_TV9_M678_PCB01_GPRS_MT6226_S01.MTG30C-MULTIV01_01B03_16m_En_Ru_Fr_Th_Vn_Cn_Ar
CM_Vertu-Silver_T6226_05C_PCB01_GPRS_MT6226_S01.A7_VERTU_V0 911C_16m_En_Ru_Fr_Malaysia_Indonesia_Th_Vn_Cn_Cn_A r_w_eeprom
SkyMix-100_985_X01_MAUI.05B.W05.44.F1_MALATA19_05B_HW_200 7-05-25__16m_En_Ru_Fr_Ar_w_eeprom
CM_Nokia-6275_1x12pin_Z9BT_5LAN_PCB01_GPRS_MT6225_S00.Z9_8L AN_02_16m_En_Ru_Fr_De_Th_Vn_Cn_Ar
ZTC-168_M500Z_PCB01_GPRS_MT6226_S01.Z600D_XY_02_00_V03 _05_16m_En_Cn
CM_Nokia-N82_E558_JQ3PAAF_E558_GPRS_MT6226_S01.V23_01_1_16m _En_Fr_Ar
CM_Nokia-N95_N618_PCB01_GPRS_MT6227_S01_16m_En_Fr_Ar
CM_TV628_TV12_M678_PCB01_GPRS_MT6226_S01.MTG30CT-MULTIV01_01B04_16m_En_Ru_Fr_Th_Vn_Cn_Ar
RATECH26_06A_PCB01_GPRS_MT6226_S01.S800FDB.26B.TS. BTM_06A_MWKS_V003.C15.H_0003_16m_En_Ru_Fr_Es_Th_Vn _Ar
CM_Nokia-6300_LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06 _48_10_16m_En_Ru_Fr_Th_Vn_Ar
Old 12-03-2007, 03:51   #2 (permalink)
marc_andrei's Avatar
Member: 340454
Sonork: 1585326
Thanks Meter: 516
thanks sir ........
br
Old 12-03-2007, 03:54   #3 (permalink)
odraregnivla's Avatar
Member: 289554
Thanks Meter: 62
nice update sir............
Old 12-03-2007, 06:57   #4 (permalink)
Member: 232607
Sonork: 100.1585040
Thanks Meter: 260
infinity team thanx for it daily good update
but there are 2 mob dead by this they have same pinout (8 pin) set was 100% on only user cod was when i format it after it mob cant back to live now these are dead then i eeprom back from bkup but still dead===
COM5 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection active
Action: write NOR flash
"smart write" active
skip: Firmware
skip: Customization
skip: Language Pack
write: Eeprom
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
chip-id: 0031:A035:3E4D
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom area
Do you want to use standard eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard eeprom address selected by user
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 00
eeprom area: 00000000:00E00000-00FFFFFF
reading [eeprom]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom_200 71129-183154.B0E.bin
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
Area: Eeprom
Write: Eeprom
Write Done
Finished, time used: 469 sec
Remove/Install battery now
after all i did like this as infinity team reply me
Hello,
Just restore original eeprom backup and phone will be back at it's original state.
Then follo this instruction exactly: http:///vbb/showthread.php?t=447277
mob still dead
there are no prob in hardware
Old 12-03-2007, 07:30   #5 (permalink)
Member: 247264
Thanks Meter: 28
Thumbs up Gr8 Update
tnanx infinity team "LORD OF THE CHINESE MIRACLE"
Old 12-03-2007, 07:45   #6 (permalink)
SHOEB AHMED's Avatar
Member: 161115
Sonork: Here you can find it...
Thanks Meter: 3,039
tnanx infinity team.................
Old 12-03-2007, 08:31   #7 (permalink)
Member: 130995
mob still dead
Hello,
What is the reason to make "format ffs" to remove user code ? Our software can read user code from phone or reset it to default value w/o "format ffs".
As I can see from your log it looks like some required data absent in your phone. It's for sure not after "format" procedure but after some other actions.
If you have made full backup before format you can restore full backup.
If you don't have flash backup you need to check operation.log file and see what was original phone version and flash phone with the same version file from support area.
After flashing press and hold phone "power" button long time (up to 30-40 sec) to make phone powered-On.
Old 12-03-2007, 09:11   #8 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,419
thanks
Faisal_computer
Old 12-03-2007, 09:21   #9 (permalink)
.::Zafar Communication::.'s Avatar
Member: 71045
Thanks Meter: 19
thanks infinity team keep it up
regards
Zafar Janjua
Old 12-03-2007, 09:25   #10 (permalink)
Member: 232607
Sonork: 100.1585040
Thanks Meter: 260
infinity team
Hello,
THANX FOR REPLY
I WILL FLASH IT AGAIN
THEN GIVE U RESULT
THANX
Old 12-03-2007, 09:48   #11 (permalink)
Member: 5504
Sonork: 100.65713
Thanks Meter: 38
hi
thanks infinity team for update
Old 12-03-2007, 09:58   #12 (permalink)
Kashif Khan's Avatar
Member: 88016
Thanks Meter: 320
Keep it up, infinity,keep it up.
Kashif Khan
Old 12-03-2007, 10:39   #13 (permalink)
Member: 515130
Thanks Meter: 304
Thanks infinity team nice update
shahzad
Old 12-03-2007, 10:49   #14 (permalink)
Miftahudin's Avatar
Member: 115242
Sonork: 100.1581364
Thanks Meter: 1,638
thanks for the good work...........
Old 12-03-2007, 11:02   #15 (permalink)
Member: 18477
i cannot understand some forum member write .read code dead chinish phone formate my phone dead .truly i say i repair many chinis phone with infinity...only one pcs not dead ...dead phone alive with infinity...dear members sorry for this words...first use ur mind .............then remind...
15 Dec 2007: "ChineseMiracle" v2.10 released InfinitySupport Infinity-Box 45 01-06-2008 21:41
19 Dec 2007: "ChineseMiracle" v2.11 released InfinitySupport Infinity-Box 41 01-02-2008 20:45
06 Dec 2007: "ChineseMiracle" v2.07 released InfinitySupport Infinity-Box 25 12-30-2007 23:56
21 Dec 2007: "ChineseMiracle" v2.13 released InfinitySupport Infinity-Box 8 12-21-2007 11:11
12 Dec 2007: "ChineseMiracle" v2.09 released InfinitySupport Infinity-Box 36 12-15-2007 13:56
Page generated in 0.24280 seconds with 9 queries
