09-08-2009, 14:07 | #1 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 08 Sep 2009: Spice, Alcatel, Huawei etc. .Spice-S820 model supported .Spice-S707N operations improved .Lenovo-S5 model supported .Alcatel-OT103 model under test .Alcatel-OT203 model under test .Alcatel-F330 model under test .Huawei-T711 model under test .Verykool-i410 operations improved .flash write improved for models with NAND flash chip .Alcatel operations improved .firmware database updated If you have Alcatel OT103, OT203, F330 or Huawei-T711 or Spice-S820 models on hands, please, make "read full flash" operation and send full flash backup files to [email protected] so we will be able to double check solutions for these models and also we will be able to add more flash files in support area. Also, please, post here test reports about Verykool-i410 unlock with this new software. |
The Following 41 Users Say Thank You to InfinitySupport For This Useful Post: |
09-09-2009, 00:52 | #14 (permalink) |
No Life Poster Join Date: Dec 2006 Location: NYC
Member: 416710 Status: Offline Thanks Meter: 391 | Verykool I410 tested with 3 method and 1 work, thanks team. here is log. ==== log: [9/8/2009 11:48:56 AM] ==== COM1 [VCP0] selected module v2.86 Action: unlock unlock method: smart fast Model: Verykool-i410 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:B703:0009 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware 67 byte(s) read connection lost error: operation failed ! Finished, time used: 6 sec Remove/Install battery now ! ==== log: [9/8/2009 11:49:28 AM] ==== COM1 [VCP0] selected module v2.86 Action: read codes unlock method: read codes Model: Verykool-i410 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:B703:0009 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware 67 byte(s) read connection lost error: operation failed ! Finished, time used: 6 sec Remove/Install battery now ! ==== log: [9/8/2009 11:50:01 AM] ==== COM1 [VCP0] selected module v2.86 Device: Verykool-i410 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:B703:0009 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation rom info detection finished rom info protocol ver: 04 ver. sw 1: LCBJ25_07B_GEMINI_PMWY_PCB01_GPRS_MT6225_S01.LBLAE 02_1_0_1_1T29M0527_M401C.BIN ver. sw 2: LBLAE02.1.0.1.1T29M0527_M401C, 00000000 ffs offset/size: 00C80000/00380000 ffs address assigned: 00C80000 detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data ... ............................................. lock area found ............................................. lock area found Patch required data Done Special operation ... detecting parameters to apply patch area 1... .................................................. .............. error: area 1 can not apply patch detecting parameters to apply patch area 2... ............................. required data found flash: EC257E25082501:29EA0000000000 flash: EC257E25082501:29EA0000000000 Write: area 21 ................................... area 2 patch applied Ok Special operation Done Write ... flash: EC257E25082501:29EA0000000000 flash: EC257E25082501:29EA0000000000 Write: lock-area-1 flash: EC257E25082501:29EA0000000000 flash: EC257E25082501:29EA0000000000 Write: lock-area-4 Write Done Finalization ... Finalization Done Finished, time used: 82 sec Remove/Install battery now ! |
09-09-2009, 00:56 | #15 (permalink) |
Member: 416710 Status: Offline Thanks Meter: 391 | You need said or write Verykool-i250 operations improved because now I tested 2 method and 1 work perfect for my I250. Someone who have dead phone test now with this version of mmodule, for me unlock work you don't loose any if you test flash. here is log. ==== log: [9/8/2009 7:46:07 PM] ==== COM1 [VCP0] selected module v2.86 Action: read codes unlock method: read codes Model: Verykool-i250 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6229:8A02:8A02]... CPU: MT6229 chip: 0031:000B:0101 status: FF rom: 4D5710FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6229,E02 Date: 2000.00.00 Version: 1.0 Version: LC1AE02.6.3.1.1T47M1103_MB53B Version: LCBJ30_07A_PMJ_HW 52 byte(s) read imei: 35646202007661 connection Ok 165 byte(s) read warning: wrong packet cs 166 byte(s) read Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 0000 Finished, time used: 14 sec Remove/Install battery now ==== log: [9/8/2009 7:46:37 PM] ==== COM1 [VCP0] selected module v2.86 Action: unlock unlock method: smart fast Model: Verykool-i250 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6229:8A02:8A02]... CPU: MT6229 chip: 0031:000B:0101 status: FF rom: 4D5710FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6229,E02 Date: 2000.00.00 Version: 1.0 Version: LC1AE02.6.3.1.1T47M1103_MB53B Version: LCBJ30_07A_PMJ_HW 52 byte(s) read imei: 35646202007661 connection Ok 165 byte(s) read reading data... reading data #2... warning: wrong packet cs building new data... writing data... warning: wrong packet cs 153 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 18 sec Remove/Install battery now ! |
08 Nov 2009: Doro, ZTE, Philips, Alcatel, Virgin models supported | InfinitySupport | Infinity-Box | 28 | 12-18-2009 14:44 |
08 Oct 2009: Spice, Haier, Zonda, ZTE... | InfinitySupport | Infinity-Box | 39 | 10-14-2009 10:46 |
16 Sep 2009: "PinFinder" v1.20: | jakoy | Infinity-Box | 1 | 09-18-2009 04:52 |
08 Sep 2009: "MModule" v2.86: | malektalha | Infinity-Box | 1 | 09-08-2009 14:20 |
08 Dec 2008: Spice-S525, MyPhone-B22, Zonda-N2000, SFR-195, ZTE-195, Alcatel-V570X... | InfinitySupport | Infinity-Box | 43 | 01-30-2009 13:03 |
