04-28-2007, 21:56 | #46 (permalink) | |
Junior Member Join Date: Apr 2007
Member: 493299 Status: Offline Thanks Meter: 1 | W210 Quote:
Thanks for your time in advanced Last edited by omega_toplist; 04-29-2007 at 00:12. | |
04-28-2007, 22:20 | #48 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Last edited by InfinitySupport; 04-28-2007 at 23:51. Reason: too complicate explanation replaced with easy-to-understand for anyone | |
05-05-2007, 05:33 | #51 (permalink) |
No Life Poster Join Date: Nov 2003 Age: 46
Member: 43076 Status: Offline Thanks Meter: 10 | Read phone info Done Verify access... Verify access Done Decode data... User code: 343 User code: 05 Decode data Done Finished, time used: 16 sec Remove/Install battery now ! here is the log for w210 motorola, is there anything wrong with that, all codes are wrong |
05-05-2007, 21:00 | #53 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | @Leo140 1. download latest updates from support area and try again 2. if software still can't read code make this: read eeprom from this phone and send to [email protected] @hiepthien please, read this: http:///vbb/showpo...70&postcount=4 |
05-24-2007, 17:26 | #54 (permalink) |
Junior Member Join Date: May 2007
Member: 504878 Status: Offline Thanks Meter: 4 | zte 231 sir cllasic c231 moto cdma help me plz relliance uim card et-box supported cllasic model infinity team is very late plz infinity team request me cllasic model sollusation add infinity-box thanks |
12-24-2008, 06:29 | #57 (permalink) |
Junior Member Join Date: Sep 2008
Member: 851822 Status: Offline Thanks Meter: 1 | Dear All pls find attahced here with all test codes Service codes Motorola CDMA: w150, w150i, w170, w170c, w200, w210, w355: Set English language: 1. Menu 2. Down 7 times, Right soft button 3. Down 3 times, Right soft button 4. Down 1 times, Right soft button 5. Down 4 times, Right soft button 6. select language now Service codes Samsung: E900 software version: *#5002*8376263# E900 full reset: *2767*3855# Service codes Spice: S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200 S410 engineer mode: *#3646633# S900 software version: *#8375# S900 serial no: *#33778# Service codes Philips: S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200 Service codes "Chinese" models: default user code: 1122, 3344, 1234, 5678 Engineer mode: *#110*01# Factory mode: *#987# Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200 Restore factory settings: *#987*99# LCD contrast: *#369# software version: *#800# software version: *#900# set default language: *#0000# Send set English language: *#0044# Send set English language (new firmware): *#001# Send Service codes BenQ: software version: *#300# test mode: *#302*20040615# Service codes Pantech: software version: *01763*79837# service menu: *01763*476# reset defaults (phone/user code reset to default): *01763*737381# Service codes VK-Mobile 3xx, 5xx: software version: *#79# software version: *#837# service menu: *#85*364# (hold #) Service codes VK200, VK2000, VK2010, VK2020, VK4000: software version: *#79# service menu: *#9998*8336# (hold #) reset defaults (phone/user code reset to default): *#9998*7328# (hold #) Service codes LG: software version: 2945#*# KG300 NVRAM format: 2945#*# -> menu 15 Service codes Sony-Ericsson: J100 software version: #82# Service codes Fly: M100 software version: ####0000# 2040(i) reset defaults: *#987*99# Send MX200 reset defaults: *#987*99# Send MX200 software version: *#900# Send SL300m reset defaults: *#987*99# Send SL300m software version: *#900# Send SL500m reset defaults: *#987*99# Send SL500m software version: *#900# Send MP500 reset defaults: *#987*99# Send MP500 software version: *#900# Send Set language to English: *#0044# Set language to Russian: *#0007# Service codes Konka: C926 software version: *320# Send C926 set default language: *#0000# Send C926 set English language: *#0044# Send Service codes GStar: GM208 (Chinese Nokea 6230+) engineering menu: *#66*# Set language to English: *#0044# Set language to Russian: *#0007# Service codes Motofone-F3: Motofone F3 software version: **9999* Send ***300* Set SIM Pin ***310* / ***311* SIM Pin ON | OFF ***000* Reset Factory settings ***644* Set Voicemail number ***260* / ***261* Auto keypad lock ON | OFF ***510* / ***511* Voice Prompts ON | OFF ***160* / ***161* Restricted Calling (Phonebook only) ON | OFF ***200608* Send: software version ***200606* Send: software version ***200806* Send: flex version ***250* / ***251* Keypad tones ON | OFF ***470* Select time format ***500* /***501* Prepaid Balance Display ON | OFF ***520* Change language Service codes Motorola: C113, C114, C115, C115i, C116, C117, C118, C122 software version: #02#* C138, C139, C140 software version: #02#* C155, C156, C157 software version: #02#* C257, C261 software version: #02#* V171, V172, V173 software version: #02#* V175, V176, V176 software version: #02#* C168, C168i, W220 software version: *#**837# C168, C168i, W220 master reset: *#**367628# Send C168, C168i, W220 E2p reset: *#**778337# Send W205, W208, W375 software version: #02#* |
12-24-2008, 06:51 | #58 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab Age: 44
Member: 476739 Status: Offline Thanks Meter: 507 | good update .................................................. ....... .................................................. ..... .................................................. ....... .................................................. ..... .................................................. ....... .................................................. ..... .................................................. ....... thanks infinity br parminder singh |
12-24-2008, 06:56 | #59 (permalink) | |
No Life Poster Join Date: Jan 2008
Member: 683463 Status: Offline Thanks Meter: 188 | Quote:
can't you read its 2007 posted | |
12-24-2008, 08:14 | #60 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | @chakrihhp If you make copy/paste you must post source where you have got information. Please, next time do not forget to say that you have copied information about codes from http://www.atm-box.com/index.php?id=utilities |
W150i,W170,W200i,W210,w355 unlocking solution witout infinity | imran777750 | Motorola CDMA | 24 | 03-17-2014 21:45 |
Tool + flash file for moto GSM W208-W205-C168i <<>> CDMA W150-W170-W200-W210-W355 | halongmobile | Motorola ODM | 13 | 07-03-2007 23:36 |
12 may 2007: Moto w150i, w170, w200, w210, w355 esn write and more | InfinitySupport | Infinity-Box | 31 | 05-28-2007 08:41 |
26 Apr 2007: QCModule v1.10: w170, w355 flashing released and more... | InfinitySupport | Infinity-Box | 16 | 04-27-2007 12:04 |
