1112 Boot Problem hi with 1112 i am facing boot problem ....the same set is booting but this one (witch is a brand new) not booting with same pinouts:confused: please check log COM13 [VCP0] selected module v2.69 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 5 sec Remove/Install battery now ! |
be sure good connection of pinout then click read or what you can do then hold power on the fone until showing reading |
@zeerik It may be that pinout is incorrect or phone connector is damaged. Double check both. |
1st Boot Err: Bad Resp UPP, 03 00 00 72 1st Boot Err: Bad Resp DCT3, 00 93 5 Rebooting Mobile |
