03-01-2016, 18:32 | #1 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Vice City
Member: 1436243 Status: Offline Thanks Meter: 99 | 16 GB eMMC Sorry for titlle this is 8 Gb eMMC Identify Code: Operation : Check / Read Info [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 41 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 15010038574D423352014D3EB6B09153 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , R3BMW [eMMC] : FLASH_CID : 15010038574D423352014D3EB6B09153 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : EE075C9DFFC27D71F2C4B2588CE372A8 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done :( Erased phone or unsupported FlashIc? Done! Elapsed: 00:00:04 Reconnect Power/Cable! Code: Operation : Flash [ v1.41 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 41 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 15010038574D423352014D3EB6B09153 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , R3BMW [eMMC] : FLASH_CID : 15010038574D423352014D3EB6B09153 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : EE075C9DFFC27D71F2C4B2588CE372A8 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : htt82_tb_jb5 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : Only one records found, and determined as universal BL : eMMC supported by BootLoader! BL : BatteryLevel : 3897 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase Error! Something went wrong! Operation Failed Elapsed: 00:01:55 Reconnect Power/Cable! Last edited by mifluvcute; 03-01-2016 at 18:37. |
03-02-2016, 07:27 | #3 (permalink) |
Member: 1436243 Status: Offline Thanks Meter: 99 | Emmc is not dead, partition is Broken i think or eMMC firmware so i Repair Firmware eMMC Problem solved with Direct Emmc and Flash with CM2 Code: Connection status: EHCI:HUB:HUB:USB 2.00 High-speed Interface: XXX High-Speed Serial number: 1234-5678-9012 Boot version: 1.03, FW version: 1.09 (Feb 20 2016 03:47:28) Insertion test... Done. Init bus... VCC: 3.3 V, VCCQ: 2.8 V Voltage levels: VCC: 3050mV, VCCQ: 2647mV, CMD: 2630mV, CLK: 6mV, DAT0: 2331mV Bus: 8 bit (HS SDR) Access mode: sector mode Power supply: dual-voltage (1.70-1.95V, 2.7-3.6V) Card/BGA: BGA (Discrete embedded) - High density MMC Manufacturer ID: 0x15 (Samsung) Product name: 8WMB3R (0x38574d423352), rev: 0x00, serial number: 0x3C545B17 Manufacturing date: Mar 2014 CID: 15010038 574D4233 52003C54 5B173150 CSD: D0270132 0F5903FF F6DBFFEF 8E40400C EXT_CSD revision: 1.7 (MMC v5.0, v5.01) Capacity: 7.29 GiB(7,827,095,552 bytes) Partition info: Boot1: 4096 KiB Boot2: 4096 KiB RPMB: 512 KiB User area: 7.28 GiB(7,818,182,656 bytes) Cache size: 64 MiB Hardware reset function: 1 Partition configuration: 0x48 Boot acknowledge is sent during the boot operation Boot partition 1 is enabled for boot Partitioning support: 0x07 Device support partitioning feature Device can have enhanced technological features Device partitioning possible Boot configuration protection: 0x00 Boot bus conditions: 0x00 Boot area write protection: 0x00 power-on write protection: possible permanent write protection: possible lock status: not locked ANDROID ROM detected: platform: MT6582, cpu abi: armeabi-v7a manufacturer: EVERCOSS board: EVERCOSS AT1A, name: EVERCOSS AT1A brand: EVERCOSS, model: EVERCOSS AT1A build id: JDQ39, version: 4.2.2 (AT1A_KP184_KP07C-QW007IB18M88E_V07_20140708) build description: htt82_tb_jb5-user 4.2.2 JDQ39 eng.chivin.1404782320 test-keys Selected: [SAMSUNG] moviNAND KLM8G1WEMB-B031/8GB (FBGA153) Last edited by mifluvcute; 03-02-2016 at 07:34. |
03-02-2016, 08:04 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | This not change fact - problem was in eMMC. Fix via USB/DA itself wasn't possible. |
