12-31-2008, 14:32 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | lg k200 format with help of pinfinder software version: 1.17 cable type: HF 4 pin (L4A) platform: MT: MT62xx (autodetect) searching adapter at COM5... adapter found, version: 2000 pins: 4, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6219 result: Rx:3 Tx:2 time required: 4 sec Power On ! format logs of lf kg200 detected CPU: MT6226MA Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219B,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7331IN00-001-R1C Version: EP1 60 byte(s) read imei: 35282701257698 connection Ok building list... done items to clear: 218 warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs items cleared: 218 of 218 building list... done items remains: 0 Finished, time used: 42 sec Remove/Install battery now ! here is imei rebuild logs Action: imei Model: LG-KG200 Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 57600 error: connection failed ! operation failed ! Finished, time used: 5 sec Power off phone now ! Imei 35282701257698 already was repaired: 12/31/2008-6:46:21 PM Continue with this imei ? Action: imei Model: LG-KG200 Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 230400 error: connection failed ! operation failed ! Finished, time used: 49 sec Power off phone now ! Imei 35282701257698 already was repaired: 12/31/2008-6:47:13 PM Continue with this imei ? Action: imei Model: LG-KG200 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6219B, E0 Hardware version: EP1 Software version: 7S7331IN00-001-R1C" Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei: 352827012576989 verification Ok Finished, time used: 5 sec Power off phone now ! |
Can we know samsung sr no with help of imei ? | pavankhatri4024 | Samsung Hardware Repair | 2 | 12-02-2009 09:18 |
Lg Kg300 Format with Pinfinity | alfox | Infinity-Box | 4 | 07-08-2009 08:26 |
After format the system with jaf of nokia n70 now no network | patelfaizu | J.A.F. By Jafsupport.com | 11 | 03-14-2009 08:15 |
LG C2500 successfull format with Infinity. | Shakeel_pattoki | Infinity-Box | 5 | 08-17-2008 13:45 |
C60 battery overheated after flashed with help of testpoint | E&D | E-Gold Based Phones | 0 | 12-29-2004 17:26 |
