12-03-2008, 14:20 | #1 (permalink) |
Insane Poster Join Date: Oct 2007
Member: 609820 Status: Offline Thanks Meter: 6 | iphone cpu 6230 LanguagePackEdit problem cpu : mtk6230 i want convert language english to turkish from this phone. i take this error : (video from rapid-share) link : http://rapidshare.com/files/169829624/__304_PHONE.avi very thanks... |
12-03-2008, 17:50 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You can contact about LangEditor support to special support person by mail: [email protected] |
12-30-2008, 12:51 | #3 (permalink) | |
Member: 609820 Status: Offline Thanks Meter: 6 | Quote:
12-30-2008, 23:16 | #5 (permalink) |
Product Supporter Join Date: Nov 2001 Location: Donetsk, DPR Age: 42
Member: 7436 Status: Offline Thanks Meter: 400 | This is not Editor trouble - you have damaged readed firmware file - Infinity Miracle check it and give name "nand_probably_damaged" - this means incorrect readed file If you read this Phone with some other flasher - Flash Tool or other - file will be damaged too, because Phone hardware give incorrect data to output with reading Flash function Now i work at this trouble to convert readed file into normal file (remove trash block's) but this is very hard work |
The Following User Says Thank You to s.Mobi For This Useful Post: |
12-31-2008, 17:33 | #6 (permalink) | |
Help china iphone copy 6230 NAND range check error | pitikor | Infinity-Box | 2 | 09-13-2009 20:47 |
nec com n880 Need file flash cpu 6230 | mehrdad20072 | SpiderMan | 1 | 07-30-2008 07:29 |
Cpu 6230 N880 | mo_gsm2013 | Chinese Models & Cloned Phones | 2 | 07-23-2008 18:09 |
Nokia 6230 bluetooth problem not the same problem as others... | sharkie2006 | Nokia Hardware & Hardware Repair | 5 | 04-16-2006 23:23 |
6230 Bluetooth problems when transferring mp3s to other 6230s | Burnt Cobba | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 08-30-2004 21:04 |
