GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   1600 bad software help me ! (https://forum.gsmhosting.com/vbb/f296/1600-bad-software-help-me-656589/)
thanhhieuqb 12-28-2008 03:32
my phone 1600 china bad software . I repair bad software with infinity but not ok , I selected 1 and 2 but not ok . help me please !
deepakgarg 12-28-2008 03:34
please log here first or backup full flash than try complete format and repeat repair bad software process again
venuno 12-28-2008 03:42
be sure good connection from pinout
read the phone then back up
format if still repain problem flash it
flash back up files it is original flash file...
Gharswild 12-28-2008 04:02
if you have a flash file back up...
much better to flash with you back up file....
thanhhieuqb 12-28-2008 04:21
initially my phone be flight mode . I have backup FW then format with infinity I see bad software ---> I try repair bad software but not ok and I flash file backup . now my phone still flight mode . I have download file inside support infinity then flash but not ok !
deepakgarg 12-28-2008 07:21
did u try safe format or complete????also please post log that is required
CONCORDIA GSM 12-28-2008 07:27
http://forum.gsmhosting.com/vbb/show...t=1600+chinese
Faheem Anjum 12-28-2008 07:34
i have this time 1112 same problem face fight mode after formating show bad software many time try but same problem //.....i flash the set also but same ............i am using this time latest exe 2.73
unlock & flash 12-28-2008 07:49
Any one pls give me 1600 and 1112 rx tx
Faheem Anjum 12-28-2008 08:03
1 Attachment(s)
sure Here is u r pinouts
thanhhieuqb 12-28-2008 09:14
I try 2 solution , format safe and compelet then repair bad software but not ok :confused:
deepakgarg 12-28-2008 09:59
i mean when phone was in flight mode just do safe format and check if phone gets bad software or its get ok..just an try
unlock & flash 12-28-2008 10:43
how to format china 1600 pls full manual paste here
deepakgarg 12-28-2008 13:54
1. make full flash backup for emergency case. It's very important step !
2. select "safe" format method
3. make "format ffs"
4. remove/install battery
5. press and hold phone "Power" button during 30-40 sec to make phone Powered-On
6. restore original imei
thanhhieuqb 12-29-2008 02:44
now . I flash file backup . my phone be flight mode , I try safe format then power on my phone gets bad software .
Page generated in 0.31445 seconds with 5 queries
