11-24-2008, 01:06 | #1 (permalink) |
Freak Poster Join Date: Oct 2001 Location: germany Age: 45
Member: 6966 Status: Offline Thanks Meter: 10 | w220 repair "telephone non autorise" orange infinty and it fails then i tried with vygis it seems to be successful but now Phones imei shows an empty field, if i press *#06* and by putting a sim card it shows "telephone non autorise" repair function don't works here is the log. COM1 [Serial0] selected module v1.29 Device: Motorola-W220 "advanced chip detection" active Action: repair Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 89886400010001:89886400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb software version: 1240-000 software version: SCY-7- Check hardware done Read data... reading Motorola-W220_eeprom_calibration-1... file saved: C:\Programme\InfinityBox\HModule\Motorola-W220_eeprom_calibration-1_20081124-005504.6AE.bin Read data done Check data... Check data done Writing... .error: required data not found or unknown eeprom structure Writing fail error: operation failed Finished, time used: 17 sec Remove/Install battery now ! |
The Following User Says Thank You to abros For This Useful Post: |
11-24-2008, 01:17 | #2 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,515 | w220 Quote:
After Unlock. If not solved repai only IMEI. BR Haicha | |
11-24-2008, 10:29 | #6 (permalink) | |
Freak Poster Join Date: Jul 2008
Member: 815644 Status: Offline Thanks Meter: 56 | w220 Quote:
11-24-2008, 15:43 | #8 (permalink) | |
Member: 6966 Status: Offline Thanks Meter: 10 | Quote:
"advanced chip detection" active Action: imei repair new imei: xxxxxxxxxxxxxxxx Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 89886400010001:89886400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb software version: 1240-000 software version: SCY-7- Check hardware done Read data... Read data done Check data... Check data done Writing... ................... unknown firmware, read flash and send to support Writing fail error: operation failed Finished, time used: 14 sec Remove/Install battery now ! | |
12 Oct 2007: SE J110i, J120i unlock, repair supported, Moto c168, c168i, w220 repair | InfinitySupport | Infinity-Box | 123 | 04-21-2011 07:54 |
SECURITY ZONE repair with NON TP method released!!! | tigran80 | DreamBox | 14 | 09-30-2008 09:57 |
w220 repair eeprom | BENCHENA | Infinity-Box | 5 | 04-30-2008 00:05 |
Repair Htc Spv M3100 Orange | Pandemonio100 | HTC & PDA WM( With Touchscreen) | 2 | 09-28-2007 11:38 |
w220 repair imei | mobile20 | Infinity-Box | 3 | 06-25-2007 10:04 |
