07-22-2010, 03:21 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | plz fix this bug COM1 [Serial0] selected module v1.38 Device: Motorola-C168 "advanced chip detection" active Action: reset settings Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89886400010001:89886400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb software version: 1530-000 software version: TCT-9- Check hardware done Read data ... reading Motorola-C168_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\Motorola-C168_eeprom_calibration-1_20100720-174241.69E.bin reading Motorola-C168_ffs... file saved: D:\Program Files\InfinityBox\HModule\Motorola-C168_ffs_20100720-174432.69E.bin Read data done Check data ... Check data done Write ... flash: 89886400010001:89886400000000 Erase: ffs Write done Finished, time used: 2 min 18 sec Remove/Install battery now ! but still in same condition so i flashed it here is logs Application: d:\Program Files\InfinityBox\HModule\HModule.exe Loading data, wait... [Infinity Box] v1.38 S/N: 0B58:0116 Wait... Device: Motorola-C168 Done Loading file v.02... C168_Main_9-1430-000_2006-May-10.69M.bin loaded Loading file v.02... C168_Flex_1430-234_PLND3_8V17_V1.69F.bin loaded Loading file v.02... C168_LP_1430-016_T677YF_8V49_V1_En_Pl.69P.bin loaded Loading file v.02... C168_Images_1430-007_T676FC_8V49_V1.69G.bin loaded Loading file v.02... C168_Melody_1430-005_T676FB_8V49_V1.69G.bin loaded Loading file v.02... C168_FileSystem_1340.69F.bin loaded ==== log: [21/07/2010 6:45:35] ==== COM3 [VCP0] selected module v1.38 Device: Motorola-C168 "advanced chip detection" active Action: flash write "format ffs" active write: Firmware C168_Main_9-1430-000_2006-May-10.69M.bin write: Flex/Customization C168_Flex_1430-234_PLND3_8V17_V1.69F.bin write: Language Pack C168_LP_1430-016_T677YF_8V49_V1_En_Pl.69P.bin write: FFS/File system C168_FileSystem_1340.69F.bin write: Images C168_Images_1430-007_T676FC_8V49_V1.69G.bin write: Melody C168_Melody_1430-005_T676FB_8V49_V1.69G.bin skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 89886400010001:89886400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb software version: 1530-000 software version: TCT-9- Check hardware done Read data ... reading Motorola-C168_eeprom_calibration-1... warning: wrong data size at 0x007F6C00, retry... warning: wrong data size at 0x007F6C00, retry... warning: wrong data size at 0x007F6C00, retry... file saved: d:\Program Files\InfinityBox\HModule\Motorola-C168_eeprom_calibration-1_20100721-064922.69E.bin error: operation failed Finished, time used: 3 min 35 sec Remove/Install battery now ! but now i have dead set in my hand than i again complete flash it but set still dead COM3 [VCP0] selected module v1.38 Device: Motorola-C168 "advanced chip detection" active Action: flash write "smart write" active write: Firmware C168_Main_9-1480-000_2006-Jun-30.69M.bin write: Flex/Customization C168_Flex_1480-001_T676ER_8V18_V1.69F.bin write: Language Pack C168_LP_1480-001_T676ER_8V17_V1_En_Cn.69P.bin write: FFS/File system Motorola-C168_ffs_20100720-174432.69E.bin write: Images C168_Images_1480-001_T676ER_8V18_V1.69G.bin write: Melody C168_Melody_1480-001_T676ER_8V18_V1.69G.bin skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 89886400010001:89886400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb software version: 1430-000 software version: TCT-9- Check hardware done Read data ... reading Motorola-C168_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\Motorola-C168_eeprom_calibration-1_20100721-070118.69E.bin reading Motorola-C168_ffs... file saved: D:\Program Files\InfinityBox\HModule\Motorola-C168_ffs_20100721-070156.69E.bin Read data done Check data ... Check data done Write ... Area: Firmware flash: 89886400010001:89886400000000 Write: Firmware Area: Flex/Customization flash: 89886400000000:89886400000000 Write: Flex/Customization Area: Language Pack flash: 89886400000000:89886400000000 Write: Language Pack Area: FFS/File system flash: 89886400000000:89886400000000 Write: FFS/File system Area: Images flash: 89886400000000:89886400000000 Write: Images Area: Melody flash: 89886400000000:89886400000000 Write: Melody Write done Finished, time used: 5 min 20 sec Remove/Install battery now ! than i decide to use old hmodule version and flash with that and set is alive and working fine here is log Application: D:\Program Files\InfinityBox\HModule\HModule.exe Loading data, wait... [Infinity Box] v1.37 S/N: 0B58:0116 Wait... Device: Aiko-51G Done Device: Motorola-C168 Loading file v.02... C168_Main_9-1430-000_2006-May-10.69M.bin loaded Loading file v.02... C168_Flex_1430-234_PLND3_8V17_V1.69F.bin loaded Loading file v.02... C168_LP_1430-016_T677YF_8V49_V1_En_Pl.69P.bin loaded Loading file v.02... C168_Images_1430-007_T676FC_8V49_V1.69G.bin loaded Loading file v.02... C168_Melody_1430-005_T676FB_8V49_V1.69G.bin loaded ==== log: [22/07/2010 7:27:43] ==== COM3 [VCP0] selected module v1.37 Device: Motorola-C168 "advanced chip detection" active Action: flash write "smart write" active "format ffs" active write: Firmware C168_Main_9-1430-000_2006-May-10.69M.bin write: Flex/Customization C168_Flex_1430-234_PLND3_8V17_V1.69F.bin write: Language Pack C168_LP_1430-016_T677YF_8V49_V1_En_Pl.69P.bin skip: FFS/File system write: Images C168_Images_1430-007_T676FC_8V49_V1.69G.bin write: Melody C168_Melody_1430-005_T676FB_8V49_V1.69G.bin skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 89886400010001:89886400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb software version: 1480-000 software version: TCT-9- Check hardware done Read data ... reading Motorola-C168_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\Motorola-C168_eeprom_calibration-1_20100722-072804.69E.bin reading Motorola-C168_ffs... file saved: D:\Program Files\InfinityBox\HModule\Motorola-C168_ffs_20100722-072841.69E.bin Read data done Check data ... Check data done Write ... Area: Firmware flash: 89886400010001:89886400000000 Write: Firmware Area: Flex/Customization flash: 89886400000000:89886400000000 Write: Flex/Customization Area: Language Pack flash: 89886400000000:89886400000000 Write: Language Pack Area: Images flash: 89886400000000:89886400000000 Write: Images Area: Melody flash: 89886400000000:89886400000000 Write: Melody flash: 89886400000000:89886400000000 Erase: ffs ffs format done Write done Finished, time used: 300 sec Remove/Install battery now ! |
New to all this (about 1 hour) :) | Mark UK | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-01-2010 09:01 |
Has someome tested this software Nokia New Series Tool? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 09-20-2000 16:39 |
5110 v5.29 "contact service" fixed with repaier by Guar | mobilemonster | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 09-16-2000 03:18 |
Happy Millenium bug | vato | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-31-1999 17:47 |
Plz help with unlock NOKIA 6110 2lock | henr | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-29-1999 22:29 |
